Results 1 to 10 of 15
Thread: sluggish start up
    Dec 2012
    birmingham
    Default sluggish start up
    hi guys after a bit of help/advise new to change glow plugs....
    well i think thats what i need to do engine somethimes on start up is very sluggish low revs nothing on peddle to try reving the engine just low revs just about running close to cuting out.. noticed the little symbol only comes on for a second( during these extra cold mornings.. just have to sit there and wait for the engine to come to life by itself.. battery is good never had any problems with it.. and reading through several posts on here.. the finger points to the glowplugs... oh and i dont get any engine managment lights etc ..
    so any advise would be great.. location on plugs tools needed or just ideas on what it is etc
    thanks in advance
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Which engine you got Fella? Guessing a CDTi 120/150, or DTi 2/2.0
    Does it start any quicker if you cycle the glow plugs three or four times before starting it?
    Dec 2012
    birmingham
    sorry 1.9cdti signum 150.. if try to cycle the light comes on first time couple seconds then does not come on again... or if it does its only its the same time span
    Jun 2012
    Barnstaple
    Does sound like glow plugs, especially if you've started to notice it more in these colder months. I recommend getting the engine red hot before you attempt to take them out as they are prone to snapping. Happened to me but luckily it popped out after 6 weeks, fingers crossed it won't happen but just letting you know, good luck!
    Dec 2012
    birmingham
    Update today car started with pre heat light stopping on for longer misses take daughter to school car gets up the road then cuts out .. LOw revs and nearly cutting out she switches engine off then tries to re start no pre heat lights and back to sluggish start again.. I have just been told maybe crank sensor gone.. Need answers if any body knows what this problem is .. Gonna see if I can get booke in to go on codereader see what comes up but if any body has had this problem and solved please help me thanks
    Regular Member conman's Avatar
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Mine was very spluttery when starting and took a while to burn of access fuel. I was getting an error for a few seconds as well and then went out and once the code was read it was glow plugs. Turned out 3 out of the 4 were knackered and I only thought it was 1 that was failing. Just be careful taking the old ones out as they can snap very easily. I just used plenty of WD40, sprayed onto them and let them sit a good 1/2 hour and then cracked them and spaying them every couple of turns and tightening them back in and out to get the threads inside lubed up. Don't forget to do it with engine warm as they will come out easier. Some guys put copper grease on the threads of the new ones before putting them in, I forgot to do mine but hopefully I wont need to change them anytime soon Just take your time at it.
    Dec 2012
    birmingham
    Gonna take it have codes checked worth the £35 see what else it throws out to cheers for both replies guys
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Quote Originally Posted by brummie1972 View Post
    Sent you a PM mate
    Dec 2012
    birmingham
    thanks sent one back
    Nov 2012
    Northern Ireland
    Trim : SRI
    Engine : 2.2 DTI
    Year : 2002
    Mileage : 98,000
    Your pm inbox is full and can't reply mate.
  1. 07 SRi Sluggish
    By obews in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 20:30
  2. sluggish
    By iokarus in forum Engine & Drivetrain
    Last Post: 29th February 2012, 20:35
  3. Sluggish again
    By durham4416 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:20
  4. sluggish
    By chrosty in forum Diesel Engine related
    Last Post: 29th December 2010, 23:55
  5. sluggish 1.9 cdt
    By thommo in forum Introduce yourself.
    Last Post: 16th March 2010, 14:57
vauxhall vectra spluttery on start up
