Results 1 to 10 of 11
Thread: Wheel jack collapsed!
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Question Wheel jack collapsed!
    As title, last night leaving work I noticed my rear passenger tyre was flat. Big screw through tyre. Got the jack etc out and when almost high enough to take wheel off the jack collapsed! Thank god the wheel was still on although the jack has damaged the side skirt!
    Jack was as new and spare un used so am very shocked
    Was thinking of complaining to Vauxhall to see if they will cover the repair and supply a new jack.
    Thoughts?
    Barrow In Furness, Cumbria
    How did it collapse? Was it located underneath the car correctly?
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    The threads slipped on my one once and ive used a proper trolley jack ever since. I think the supplied jack is only designed for use in emergencys.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Very common, seen one fail in front of me (Hyperhart's at one of our meetups) and seen several people post about it. Someone posted the other week their's had snapped.
    They are only designed for emergency use, but yeah it's pretty crap if that's when they break and you haven't used it regularly or anything.
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Had the same problem with my vectra b (they use the same silly jack) now I bought a proper jack for my vec c.
    Nov 2009
    south wales
    Changed hundreds of tyres before. Was a flat surface and jack located correctly. Got two trolley jacks at home but as stated was in work so would assume I could rely on this Vauxhall supplied jack in that situation!
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I used to use mine regularly, but even I've had a twitchy bum moment when the last one slipped doing suspension, bottom lips bit bent but luckily it jammed under the car and saved the skirt, still semi jacked up!!
    South east
    I keep a bottle jack in the boot for emergency, road-side situations, and a trolley jack for repair work at home.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As per other posts on here if your looking for a replacement for these scissor jacks look for a saab 9 3 one there exactly the same design but they are far more sturdier than the rubbish ones that vx supply
    and still loving it
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Seen this happen too. I always put the wheel under the car in case the jack collapses.
  1. Help! Passenger Side Collapsed!
    By Diesel279 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2009, 20:32
  2. Wheel stays on the ground even when jack is used...Any ideas?
    By sparky71a in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2007, 14:22
  3. Auto box 'collapsed'
    By Pete in forum Engine & Drivetrain
    Last Post: 5th June 2007, 22:42
  4. Wheel Jack Trouble
    By jontymo in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2007, 16:47
