Results 1 to 10 of 13
Thread: wheel hub
    scotland
    Default wheel hub
    need to buy a new n/s front hub , what is the part number for 2004 1.8 ?
    also ebay ones ?? which is reliable and cheap
    durham
    Trim : Leather
    Don't buy the cheap ones off e bay mate, do a search I've posted my thoughts on bearings, buy genuine! I had to do the job twice through a one that lasted all of seven weeks!
    scotland
    did you buy one without a gaurantee ? some have 12 months atleast ?
    durham
    Trim : Leather
    I bought what I thought was better than a £55 one off eBay ,I got a Lucas one from ecp. And yes they do have a guarantee and I took mine back . Just trying to save you doing the job twice bud.
    Jun 2011
    brum
    There is a part numbers request forum by the way
    Given the info you provided i'd say you have the older hub which is replaced with P/N 93186387 (this goes up to chassis number 48999999, they were changed after that 93186388)
    Edit: Although i don't think you would, but since im no expert, if you have IDS (you have a sport switch that does something), then theres a different P/N!
    scotland
    cheers DJ , I got the p/n mins after I posted .
    its one without ids i'm after .
    its only to clear an ABS fault the bearing itself is fine .
    Jun 2011
    brum
    Yep ive got to go out saturday and check my abs wiring, but i have a feeling i'll be buying a new hub too, just my luck the sensor will be fudged and not just a bare wire. but i live in vague hope of an easy fix saturday
    scotland
    ha , this is my last resort on it , checked all the wire an connections but with a meter it looks like the hub sensor thats gone
    Jun 2011
    brum
    if you dont mind me asking, how did you test it with a meter. I read (on here i think) that the vectra abs sensors can't be resistance tested like most and you have to do a voltage check to be certain using flying leads (which i don't have incidentally, and i have no idea what they are specifically and where to get them).
    Of course mines a newer '08 1.9 cdti 120, so there's of course a very good change the sensors are different to yours
    scotland
  1. Steering wheel controls..button V roller wheel
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 18:18
  2. alloy wheel refurb. £20 per wheel, Birmingham
    By dannydm1 in forum Detailing and Car Care Discussion
    Last Post: 3rd September 2011, 18:42
