Results 1 to 10 of 17
Thread: Help needed 1.9cdti 150 manifold fitting Fareham
    Regular Member Al 150 cdti's Avatar
    fareham hampshire
    Engine : 1.9cdti 150
    Default Help needed 1.9cdti 150 manifold fitting Fareham
    very very sad day, the time has come :-(
    Help needed to fit vectra 1.9cdti 150 manifold in the fareham area.
    due to not having a bottomless pocket I can not afford garage prices but am very willing to pay someone from here if they know what there doing as Ive see the how2 and its out of my depth I think.
    Thanks Al
    fareham hampshire
    a samsung galaxy s3 would be a gift for your troubles?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i take it you have the replacement manifold already to fit?
    fareham hampshire
    not yet as i have only found out today, changed oil yesterday and noticed so read tho a few how 2s and since i alligned all swirls to the bar the car is ****ed, on swirl 1 is stuck. no 2 moves with a screwdriver (swivels) 3 stuck as expected (actuator) 4leaking oil and is loose as hell (bearings)and since i tried to put the bar back on, the engine management light is on (alligned all tumbles) and lose of power as expected and wont drive above 3000rpm
    thanks Al
    Slough
    73 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    send carl ( nurton ) a pm and see if he can help , not to far away from you and he seems to whip them in and out in no time .
    the vectra has gone , but not far away so ill still see it form time to time
    Jun 2009
    South Coast
    I have not done one of these on the 150 but would get together with Nutron if he is up for it.. He says its takes about 4 hours to change one over..
    I was reading on your other thread that others were saying this manifold may not be your issue though..
    fareham hampshire
    i am sure its the issue as i knew it was gone and lasted around 6months. I changed the oil yesterday and noticed it had got worse and the rod was off so re aligned all tumbles to the rod and since then the car is ******ed took it for a run round the road and complete loss of power, thanks
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Yeah I'll be about and I'll not do the stupid thing I did last time again... nuf said
    Jun 2009
    South Coast
    I will wait for Nutron to come back to me before we can commit to anything..
    fareham hampshire
    Nutron are you up for this? what you do last time,sure it was a learning curve
  1. Help needed 1.9cdti 150 manifold fitting Fareham
    By Al 150 cdti in forum Engine & Drivetrain
    Last Post: 28th January 2013, 23:30
  2. Post Manifold Fitting Woes
    By robdd1 in forum Engine & Drivetrain
    Last Post: 13th April 2010, 15:44
  3. Time Manifold Change 1.9CDTI (150)
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 19:06
  4. sri 1.9cdti 150 inlet manifold
    By neil mc in forum Engine & Drivetrain
    Last Post: 11th August 2007, 00:30
