Thread: Poor Ground causing dimming bulb
    Nov 2011
    hg4
    Default Poor Ground causing dimming bulb
    for a while ive had an intermittent bulb (out warning) light on the dash, its one of the rears in the boot lid left hand side as you stand at the rear, the stop light. but its really dim not actually gone.
    Am i looking at a bad ground somewhere, i've tried varying things to get the light on/off on the dash but can't sus it, any ideas
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It could still be a bad bulb, swapping all the bulbs from one side to the other will pinpoint the fault to the bulbs or the light fitting.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    they share a common ground so it wont be that..
    Probably a dodgy bulb holder, so maybe a replacement bulb holder assembly for that side.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you removed the bulb and physically checked bulb holder.
    fairly common for a bulb holder to build up resistance due to corrosion. 2 mins with some emery cloth and it'll be sorted.
    Nov 2011
    hg4
    will take a look thanks guys
  1. Instrument Dimming Bulb Output Circuit Open or High Voltage
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2016, 20:24
  2. What could be causing it?..
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 21:10
  3. Could This Be What's Causing The Vibration?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2010, 18:24
  4. Can i ground my amp to the stereo ground?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2009, 17:07
