Thread: Vauxhall Signum Diesel 05 plate fault code P1483
    Mar 2011
    Margate
    Default Vauxhall Signum Diesel 05 plate fault code P1483
    Hello people
    I have had a code come up on my signum, it is P1483,
    I believe this is something to do with the fan.
    I have the spanner light on all the time and I was wondering if this is going to cost me lots of maney to get right.
    I have been told by a garage that this is not a major issue and I can still drive the car around.
    Is this right and If it can be fixed does anyone know how much and can I repair it myself?
    Many Thanks for your time.
    Marc Cook
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    It may be ok whilst the temps are low. Soon as the Warner weather appears you may get problems.
    it may not be expensive as could be as simple as a fuse
    Mar 2011
    Margate
    Thanks for your response , sorry if i sound dumb but do you know what fuse it could be, is it in the car or under the bonnet?
    West
    Have the relay & the fan wiring checked, if the fan is working it may only be working on 1 or 2 speeds, iirc it should be a 4 speed fan... tech 2 can force the fan on & check which speeds are working.
    Mar 2011
    Margate
    how much am i looking at for a new fan, and can I do it myself?
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    As above 4 speed settings.
    I had an Astra the other day where the fan didnt work.
    and it was internally shorting in speed setting 2
    not sure on vec Astra was a 40 amp near front of engine fuse box
  1. Code P1481-P1482-P1483
    By Aikon58 in forum Troubleshooting
    Last Post: 30th July 2013, 12:30
  2. Fault Code P1483
    By chas901 in forum Troubleshooting
    Last Post: 11th December 2012, 17:41
  3. Fault code P0638 2.2 DTi o4 plate
    By Ian666 in forum Troubleshooting
    Last Post: 10th February 2012, 18:16
  4. 150 Diesel fault code problems
    By dannycturbo in forum Engine & Drivetrain
    Last Post: 25th January 2012, 14:46
  5. water in diesel filter, spanner light and fault code
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2011, 19:24
p1483
vectra c 2.2 dti engine code p1483
fan relay 3 vectra p1483
p1483 opel signum
p1483 code
p1483 fault code vauxhall
