Thread: 3.0v6 cdti 183BHP 06plate loss of power.EGR valve suspect
    Aug 2012
    kent
    confused 3.0v6 cdti 183BHP 06plate loss of power.EGR valve suspect
    Driving back last night on a 150 mile round trip the engine started to loose power but still keep up with traffic at motorway speeds.Engine management light came on 5 miles from home,got to within half a mile of home and lost all power(not able to get up a short but steep hill),engine still ran on normal idle speed but could not pull away even on flat road.After waiting for recovery for several hours i managed to start it and drive back home with engine light on but no noticeable fault present.Took it to main dealer for diagnostics this am,various faults pointing towards the EGR valve,although they could not be sure!Parts not in stock so coming from factory & car booked in for next week,currently driving ok since but only done30 miles so far today.Has anyone had this or come across the fault before,Tony.
    Oct 2010
    Lincoln
    Had a similar problem a few weeks ago. Independent looked at fault codes and it pointed to EGR faulty. Had it replaced and all fine now apart
    from a split turbo hose!! Didn't lose all power though, just wouldn't go above 3000rpm.
    Aug 2012
    kent
    Thanks,the technician said it looked like the EGR had been completly jammed on the various codes that came up,fault not present since last night,during diagnostics or driving.Lets hope stays ok till Monday as got to use the car for the next 4 days!
    Oct 2010
    Lincoln
    Mine actually kept repeating that the code was there but not present? After replacement codes show nothing so obviously it was on its
    way out!!
    Oct 2010
    Lincoln
    Oh and good luck! Replacement of this is in the region of £300 cos is't a sod to get to!!
    RO - Rocking all over the UK And Poland jaqubek's Avatar
    Sep 2011
    london
    36 Post(s)
    2 Thread(s)
    Vehicle : Vectra C Estate
    Engine : v6 3.0cdti
    Quote Originally Posted by lencuff View Post
    Did you pay 300£ to replace EGR on Z30DT?? Man, you`ve been robbed
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Not unheard of a v6 egr valve. Low miles?
    can't comment on price no idea how much they cost just egr isn't to bad to fit 1hr tops
    It sounds very much like the initial symptoms of EGR Valve failure
    However, it on mine (Y30DT) it was the Emissions Warning light that came on once the engine was hot
    On initial activation the EMS Warning light would come on and then engine put into Safe Mode, but after this it was just the Emissions Warning light that was left on for two days
    As with all sensor failures, they start off erratic and can normally be left alone until it becomes more permanent, and on mine it took nearly 6 months before it was occuring consistently after the Emissions Warning light had cleared
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    You are looking at less than £170 for the EGR valve (part only) on the Z30DT
    Aug 2012
    kent
    Yep the part number & price is v0097356078....£135.00 Main dealer fitting quoted at 1.2hrs because the two lower bolt are not easy to reach it means the inlet manifold needs lifting,hence an extra £8.00 for sealant & gaskets. All fitted now ( Tuesday Pm,seems ok so far) The valve was found to be stuck open when removed,the fault showed up again 4 days after initial problem & again on drive to garage!
  1. 1.9 cdti loss of power
    By mark1484 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th July 2011, 08:12
  2. Power Loss on 3.0 V6 CDTI
    By V6Andy in forum Engine & Drivetrain
    Last Post: 1st March 2010, 23:59
  3. loss of power 150 cdti
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 17th May 2008, 14:24
  4. Power Loss Update! No new EGR valve needed (yet!).. all coz of Vectra C.com!
    By nickyg in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2008, 18:22
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
https:www.vectra-c.comforumshowthread.php179529-3-0v6-cdti-183BHP-06plate-loss-of-power-EGR-valve-suspect
vauxhall vectra z30dt egr symptoms
egr valve signum v6 cdti 2007
z30dt egr symptoms
vectra c 3.0 v6 cdti power loss
opel signum 3.0 v6 cdti 2008 power loss
p0409 vectra v6
p0409 egr valve sensor a vectra c v6
part no v0097356078..
is i easy to take off egr valve vectra v6 cdti
opel vectra 3.0 cdti lose power
vauxhall vectra v6 egr valve location
z30dt power loss above 3000rpm
