Thread: Off to look at a 3.0 cdti Siggy - any advise?
    Regular Member d_ghedia's Avatar
    Oct 2007
    Berkshire
    Vehicle : Vauxhall Signum
    Engine : 1.9 CDTI 150. Manual
    Question Off to look at a 3.0 cdti Siggy - any advise?
    Im going to be looking at a couple of Signum 3.0 v6 CDTIs this weekend and next. Both are facelift 2005/6 models, manual. One has 80+k on the clock and the other has 107k on the clock.
    What should I be checking and looking out for in the mechanical, electrical and interior. Is there anything specific to the 3.0CDTI engine that I need to take into consideration?
    There doesn't seem to be many problems reported about this engine so I am hoping/assuming its very reliable and pretty much bomb proof.
    Thanks in advance for any info.
    As with all Vectra based bodies, check the suspension throughly (springs, shocks, and ARB)
    With the engine :
    Check the revs on idle and then allow to warm for about 10 minutes
    Switch the Air Con on
    Switch the engine off and check the engine oil level (as it should be checked when warm)
    Restart the engine, then take the car for a drive at 50mph, and set the Cruise Control, of about 5 miles
    Whilst doing this you can check all the switches work and that the Air Con has gone cold
    durham
    Trim : Leather
    Good avice there it's a cracking engine.
    Regular Member renodci's Avatar
    Kent
    Cambelts on these are due at 100k I think, so the one with 107k on the clock should have proof that it has been changed.
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Check there's no misfires my old one had at 1500rpm was annoying at times
    Apr 2012
    Norwich
    Mine also appears to have a mis fire at 1500rpm. David - did you get it sorted?
  1. my new siggy v6 cdti
    By david-bell in forum Quick Photo Album
    Last Post: 31st May 2011, 22:07
  2. vectra 1.9 cdti problems please look and advise
    By haigy in forum Engine & Drivetrain
    Last Post: 6th June 2010, 20:54
  3. 3.0 Cdti Siggy Elite going
    By Trev in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 5th October 2008, 19:05
  4. 1.9 CDTI Siggy 150
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 22:26
  5. New CDTI Siggy
    By Yossarian in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2007, 08:20
