Thread: Ignition coil screw fixings
    Aug 2011
    Bristol
    Default Ignition coil screw fixings
    I have just gone to change the coil on my sig.
    When trying to remove the bolts 3 of them did not seem to move up when unscrewing.
    The coil removed and I now have 3 small metal threads that are supposed to sit in the cylinder head out.
    Obviously at some stage this has been overtightned and the thread has been pulled up.
    I can put them back in but I want to know if I should put anything inbetween that will secure the thread in place?
    Is there anything that will stick metal to plastic that I should use (locktight maybe)??
    Regular Member sir pingu's Avatar
    Jan 2012
    Klarup DK 40 cm away from Keyboard
    Vehicle : Vectra Estate Irmscher 3.0 CDTI
    Engine : Z30DT
    Year : 11 06
    Mileage : 301000 KM
    If its a place where it is posible to work, then I would go for helicoil.
    Aug 2011
    Bristol
    They sit on top of the rocker cover.
    They look like what I am talking about.
    Should I replace these then or just try and stick the others back in
    Jan 2012
    Engine : Z30DT
    Year : 11 06
    Mileage : 301000 KM
    You can't put the threads back in. You'll have to put helicoil in instead. Helicoil are new threads and is a god solution on defective threads. Or maybe you just could put new and a little longer bolts in. Try to see if theres a little bit of threads left.
  1. Mudflap fixings
    By John LE in forum Bodywork & Interior
    Last Post: 2nd January 2012, 01:18
  2. 2007 Vectra Ignition Coil Help
    By heathersonline in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2011, 09:09
  3. Ignition coil and problem starting?
    By emptybee in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:36
vauxhall vectra ignition coil bolts
