Thread: No reaction to accelerator
    Jan 2013
    Glasgow
    Default No reaction to accelerator
    I need everyone's help as my car developed faults today and I need my Vectra everyday and now it won't rev and idle revs are 1400 and fallowing faulty show:
    P0400 - Exhaust Gas Recirculation Circuit High Voltage
    (01) - Present
    P0110 - Charge Air Temperature Sensor High Input
    (11) - Present
    P0651 - 5V Reference Circuit 2 High Voltage
    (05) - Present
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check the voltage at the battery with engine running. When my alternator failed, the exact same thing happened - random faults, high idle, and no accelerator
    Also try disconnecting EGR and MAF and see if it works
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Sounds like a faulty egr and maf sensor
    Jan 2013
    Glasgow
    I disconnected them and it makes no difference. How did you know alternator was faulty?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Kaz View Post
    First indication was the battery light showing on the dash board, and 8 volts at the battery with engine running. Got it towed home after it stopped. Jump started, battery voltage was down to 4 volts and the accelerator had no effect at all. New alternator fitted, jump-started, and all was fine
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Kaz where in glasgow are you. I can check your alternator if you want.
    3.2 v6 Signum and loving it
  1. Accelerator pedal
    By Mopar Man in forum Diesel Engine related
    Last Post: 8th December 2011, 20:41
  2. Nearside rear upper torque/reaction arm slight play in a pin/bush
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 12:46
  3. accelerator goes 'flat'
    By Videoman in forum Engine & Drivetrain
    Last Post: 30th October 2009, 12:22
  4. no accelerator!!!
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 5th November 2008, 22:38
