Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Cim replacement
    Jan 2013
    North yorkshie
    Default Cim replacement
    Hi,
    Just searched quickly and found nothing but could be doing it wrong, so sorry if so, it's a fairly common complaint.
    i need to replace the CIM in my friends 53 vectra 2.0 dti, the module is a delphi and has codes 4536 9008, 0301221416, 13132475(found this code CIM on eBay £50) which codes need to match? Ident code is GL, does this need to match?
    Cant find a how-to guide on net and am really surprised! Am I right that I physically replace unit but keeping original ignition barrel then phone out a decent vauxhall independent to programme keys in via tech2?
    any advice would be great
    also any tech2 recommendations around northallerton, north yorks would be great( ball park figure£££??)
    thanks in advance
    Jan 2013
    North yorkshie
    This has same codes, doesn't mention being tech2 cleared, is that a problem?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    If it's not Tech2 cleared, you'll need the security code from the donor vehicle I believe?
    Admin plasma's Avatar
    On the Forum
    224 Post(s)
    Engine : 150
    Mileage : 74000
    u need either the code for it supplied by the person who removed it or its a lump of junk mate... dont know if u can pull the vin number from it otherwise..
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jan 2013
    North yorkshie
    Ok, I need a tech2 cleared one. Anything I need to watch for? Ball park for mobile programming??
    Jan 2013
    North yorkshie
    Thanks for advice above, I've bought the one above but that is tech2 cleared.
    again ANY advice would be ace, I've been told there is a knack to getting steering angle right, can I just replace the same way as I found it?? Changing locks an issue?
    ta
    Full Member Sebastian's Avatar
    Electric Heated Recaro Leather
    35 Post(s)
    Engine : 1.9 DTH
    Take it somewhere that they know what they doing , as incorrect fitting can lead to snap airbag ribbon cable also u do need tech2 to program it and to program ur keys, if u thinking of fitting that urself then get it tech2 is a no no too as u wound start the car
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It's not just the keys that need programming the whole car does as the CIM is the gateway for all modules.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I have one from 58 plate. Dont think it'll be right for ur car.
    Jan 2013
    North yorkshie
    Got one fitted now but thanks humourbash.
    How would I snap airbag ribbon? I've fitted one now so fingers crossed I ain't done that! I've been careful.
    cant take it to garage as car not worth enough, stealers would write it off. I'm not risking much at £50 so here goes..... I'm fairly handy, but will get a prof to do tech2. Will do major ring round tomorrow morning.
    is there a set up for steering angle? I haven't moved car and have put new one in the same as old one came out.
  1. replacement key
    By jabba in forum Troubleshooting
    Last Post: 22nd April 2012, 15:03
  2. Replacement GID - what to look for?
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 16:22
  3. DMF Replacement
    By daviem-rfc in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 14:01
  4. DMF replacement
    By silky in forum Engine & Drivetrain
    Last Post: 4th May 2009, 08:09
  5. Replacement for the Vec
    By AJA in forum General Chat
    Last Post: 23rd June 2006, 18:56
where is the matching codes on vectra c cim
cim replacement with tech2
vectra c cim module repair
vectra c cim module removal
