Thread: Air in brake system keeps coming back
    Regular Member looloo2's Avatar
    Dec 2011
    Kettering Northamptonshire
    Default Air in brake system keeps coming back
    Right the story so far is that the car needed a new master cylinder which was fitted around 9 months ago, after this the car was fine for around 3 to 4 months
    However afterwards the pedal started to feel as if air was back in the system, and the pedal lost its feel and gained more travel unless pumped. Now after multiple bleeds the problem remains however by bleeding the brakes the problem disappears for a month and then slowly returns.
    the system has been pressure bled and manually bled multiple times so suggestions would be grateful!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check master cylinder seal its probably drawing in air
    Dec 2011
    Even though its not that old they could be perished already ?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It could be they where damaged.
    Dec 2011
    Okay bud cheers ill check it ASAP
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Also worth doing a complete check of brake lines and abs pump. Checking for corrosion and any sign of and fluid.'
    fliiding getting out means air can get in
  1. I may be coming back to a Vec C !
    By tyreman in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2012, 21:00
  2. Might be coming back to VX!
    By steveked in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2009, 10:54
  3. Coming Back to VX
    By Neil in forum General Chat
    Last Post: 9th January 2009, 09:08
  4. I'm coming back!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2008, 07:03
  5. Coming back to a Vec
    By auximinies in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2007, 23:18
