Thread: autobox problem?
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Mileage : 119k
    Default autobox problem?
    Not sure if I have a problem with my auto box or not really. Car is a 08 vectra cdti sri 150 auto with 87k miles.
    I've had the car remapped by mas performance with egr and dpf deletion.
    Today I experienced some strange behaviour. While the car was still cold, only been running 2 minutes, I had to pullout into a small gap in the traffic on the duall carriageway. I put my foot to the floor and after the usual 2 second delay the car pulled away. However, it seemed to get stuck in either first or second gear with the revs climbing but not much else happening. I had to completely back off the throttle. Then pull away again gently.
    I have also noticed on a few occassions previously that the box seems to hold the lower gears slightly longer than I think it should. This happened before the remap and also with the car cold and when warmed up.
    So, was today's problem just down to the car being freezing cold and the gearbox oil being too cold or something more sinister?
    I'm wondering if the auto box needs a fluid change or the level is slightly low.
    Any help appreciated as usual guys.
    Chris
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Why are u flooring a cold car for a start ??? And the answer is possibly tje gear box was confued its happens some times is it ok now
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Or possibly diff slip
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Quote Originally Posted by paulvectrac View Post
    Dont normally do it, but the dual carriageway is a busy one and you dont get many opportunities to pull out. After the incident, it drove fine for tge rest of thr journey.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Possibky logic lock mate did it a fee times in my old auto just keeo an eye on it
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Auto boxes tend to hold gears longer when cold, it helps them get upto temp. quicker, but it shouldnt last for more than a few minutes. Im guessing in your case it got confused (they are a bit dim witted at times), it maybe due to the remap, the autobox does have some learning paramiters, so its possible to confuse them if going from a steady drive to a 'sporty' drive in an instant. Tiptronic mode overrides this i found.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Thanks for the replies fellas. As I said, booting it from cold is not something id normally do. Ill keep a close eye on it.
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Give it a fluid change
  1. 2004 vectra c autobox problem
    By craig1 in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:56
  2. Autobox problem
    By 24vElite in forum Engine & Drivetrain
    Last Post: 26th January 2009, 21:48
  3. Veccy C autobox problem
    By Del in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2008, 16:12
  4. Another 2.2 Autobox Problem
    By paver in forum Engine & Drivetrain
    Last Post: 5th October 2008, 11:59
  5. Please give me some advice Autobox problem ???
    By Woodenman in forum Engine & Drivetrain
    Last Post: 5th April 2007, 20:01
