Thread: Arghh! Annoyed!!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Arghh! Annoyed!!
    Got free alloys from mate who got sri alloys so decided to take it and use it finally to get rid of steels with alloy wheel look a like trim, also it's not straight/true, as it makes steering wheel vibrate as in fast wobble. Friends/forum reckons warped brake disc or wheels need balancing. Even tyre garage said so too. But i didnt believe it would be them!
    Anyways, cleaned and checked them alloys is undamaged (apart from slight kerbings on 2) its straight and true!!
    Tyres was near limit and i got them 8 month old tyres on mine. Removed tyres at home, so set off to tyre spot normally £13 per wheel, i got it for ten per wheel to remove tyre and fit to alloys
    The guy found 2 near limit at end of tyre. 7mm 7mm 7mm but at end wearing out faster as if its used that area 95% of time.
    Guys said tracking is off.
    Went to boss and said, you done tracking 3 times, new tyres with you, still not happy i have to replace 2!
    Boss offered free tracking!
    Good job it's 1mm away from balding and is safe to use after tracking properly,
    I think when they do tracking. You ask to take it for a drive. Then return to let them know if its spot on. But when you return, tell them you feel it is slightly off just so they check again, this way you can be sure it have been done right cos as you leave the garage, driving is completely different to standstill!
    Off i go to find same mm threads to replace them tyres for peace of mind!
    Not happy at all really!!!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Ohh, the steering wheel stopped vibrating now. It was the wheels not straight and true!!!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I'll be honest, I didn't really understand most of that
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Guessing the tracking was out by quite a fair bit, causing vibration? Had this before after balancing, and replacing brake pads/discs.
    Test drive after tracking adjustment is always a good idea. I've only had to return once after tracking adjustment, for re-adjustment, the only time I've used Kwik Fit for tracking..........
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    + 1
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    + 1
    + 2
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Sorry guys i was a bit drunk and very tired when i wrote that! Pmsl
    Basically had new mid range tyres fitted, half price tracking and 5 point checks free.
    5 months later puncture repair on one. Not mentioned car need tracking, it was the guy i doubt likes the job. He should of said to me that inner side next to wall showing signs tracking is off. Cos hes a pro know tyres and signs etc
    Now cos i swapped rims over to alloys cos of steel wheels was warped. I was told tracking was off cos mate/boss was doing it, i was not happy as it is near minimum so gave me free tracking and did it himself. Now need 2 new tyres soon and now vibration stopped. A smooth ride.
    Dec 2011
    Seaham
    Google do a great translation service......
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by Ben50n View Post
    I know they are good, but they are not miracle workers.
    3.2 v6 Signum and loving it
  1. arghh
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2009, 18:54
  2. A bit annoyed...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2009, 21:22
  3. Right Annoyed
    By chrisf70 in forum General Chat
    Last Post: 28th January 2009, 14:19
  4. I'm f**+ing Annoyed
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 17th December 2008, 17:36
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
