Thread: tracking settings
    Regular Member Higgins's Avatar
    Dec 2005
    Aylesbury
    Default tracking settings
    Anyone know the camber/alignment measurments for tracking machines as most garages dont have them yet
    56 plate 19" wheels
    Any ideas peeps
    http://www.vectra-c.com/forum/showthread.php?t=17938
    They should be just about the same for any car...
    zero degrees between left and right
    member of the smoke patrol 230bhp+
    hope your not thinking of changing your camber settings
    what are you hopping to do
    Dec 2005
    Aylesbury
    Well i hit a brick in the road and it has put the trackig out but most garages dont have the correct settings to do it. So i just wondered what the settings are so i can tell them? I have had it done twice but they cant get the steering wheel centre
    errm.. i'd try going somewhere else then mate...the 1st thing you do when tracking a vehicle is to set the steering wheel and clamp it off.. then adjust underneath..
    Try somewhere with a laser system as the settings are the same for all the vectra hatch's with sports suspension..and they will be stored on the database of the computer..
    Dec 2005
    Aylesbury
    so ill just get them to track it the same as a 04 vectra then and that should do the trick??
    Yep.. should do.. and if the steering wheel is out of alignment but it runs straight then thats not the fault of the tracking, it's poor alignment of the wheel to start with..if the wheel has to be held as it's running off left or right then thats poor tracking..
    Dec 2005
    Aylesbury
    as in poor alignment of the steering wheel you mean?its only done 6k but i can never remember it being stright. hopefully that would be a warenty job. ill just go around and bug a few people today and see if we can get it centre
    okey dokey.. good luck!!...
    Next time you get the tracking done, watch how they do it, and look at all the readings
    The front might be something like...
    -6 on the nearside
    +3 on the offside
    This gives you -3 degrees, so it needs to have 3 degrees added to the nearside
    Now looking at the rear it might be...
    +4 on the nearside
    +2 on the offside
    Sadly, there isn't much you can do about that
    This is usually caused by several factors like the amount of fuel in the tank and the tyre pressures
    So before you go...
    Remove EVERYTHING from the car
    Set the tank to about 1/2 full
    Check all the tyre pressures are correct (cold setting)
  1. tracking settings
    By WHOOSH05 in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2010, 22:31
  2. tracking
    By happypostie in forum Bodywork & Interior
    Last Post: 24th April 2009, 08:57
  3. tracking
    By bigron1988 in forum Suspension, Wheels & Brakes
    Last Post: 31st October 2008, 17:20
  4. Tracking.
    By MLC in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 21:39
  5. Tracking
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2008, 12:27
