Thread: More faults... maybe?
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    Default More faults... maybe?
    Been having issues with cold start on my Vectra cdti 120 since changing my fuel filter housing and thermostat housing. i've tried a start today with the temp sensor disconnected and it fired straight away, so its been run today with it disconnected. I've got back from work and fitted another new sensor and plugged it back in...
    While plugged into the laptop to clear eml one of the fault codes is throttle actuator sensor.
    A guy down my street maps cars and does diagnostics etc, he's reset the faults and its driving spot on, temp gauge is working fine, so hopefully in the morning it'll start fine...
    My worry is now if this fault regarding throttle sensor comes back!!!
    Whats the fix???
    Would running the car without the temp sensor plugged in today have owt to do with this???
    Don't think so but worth asking???
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Was it set a present or not present?
    may just be slightly gummed up an need a clean.
    Mar 2012
    cheshire
    11 Post(s)
    Is that easy enough on a 120?
    Bl**dy car's testing my patients.
    Mar 2012
    cheshire
    11 Post(s)
    It was in present, we cleared the faults but the lights back on now...
    Will get it read again later on it the week.
    Had pipe off throttle body and have give it a quick wipe/ inspection.
    Looks to be alittle oil in there, i'll strip it down for clean over weekend if possible after codes are read.
    Mar 2012
    cheshire
    11 Post(s)
    Today it's cleared itself, so tonight I've had it back on laptop. It was error 1125 throttle actuator sensor.
    Maybe the clean has helped for now?
    I still plan to strip throttle body down for a spring clean.
  1. ?Faults or not.
    By daddy5times in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2013, 13:46
  2. OP-COM faults
    By WoodleySaint in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2012, 16:36
  3. VEC FAULTS X2 Anybody help???
    By DonMafia in forum Introduce yourself.
    Last Post: 25th January 2009, 17:02
  4. Vec c faults
    By Rickiek123 in forum Bodywork & Interior
    Last Post: 19th January 2009, 21:43
  5. Car Faults
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2007, 14:11
