Results 1 to 10 of 14
Thread: EGR
    Feb 2012
    Walton
    Default EGR
    The little engine light on the dash has come on so I looked in the manual and it says emissions.
    Is this likely to be an EGR fault and if so can I get rid of the ****** thing? (used to be first thing to do with land rover engines)
    Feb 2012
    Walton
    Forgot to mention the spanner light has come on 3 times now in about 2 weeks aswell
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Yes, you can buy blanking plates to remove the EGR out of the equation, but you will get the spanner light, then that will go out and you will be left with the little engine/emissions light.
    EDIT: Just looked, you have an estate, it could be the DPF trying to regen?
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    emec#7
    Feb 2012
    Walton
    It's a pre face lift 3.0 v6 cdti so would this have the dpf?
    Engine : 1.9 CDTi
    Could be anything.
    Get the codes read before replacing random stuff.
    Feb 2012
    Walton
    it's going on the code machine at work tomorrow and we'll go from there
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Emissions sign can relate to anything mate.
    Feb 2012
    Walton
    Well it went in for MOT todAy as it was booked. Failed oon rear brake imbalance due to one sticking on. Passed emissions and then this evening after leaving the car to warm up the light went off. Drove 70 miles home and still fine.
    I did take off the tuning box last night though but it'd been running fine with that for 10 month. Going to get it on the code reader when we have time but need to sort that caliper out first job
    Feb 2012
    Walton
    Right. Had it on the code reader and it saying no reading from egr and what apears to be a waste gate push rod fault.Suggestions welcome
