Thread: glow device general error
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default glow device general error
    Anyone know what need doing relating to this? Got mixed results on the forum but changed from vx the new glowplug relay as this was faulty. Now this glow device general error comes up.
    Hope u can help.
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Are you getting a voltage at the plugs?
    whats resistance of each plug?
    Usually fault is with 1 or more glow plugs faulty
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Thought it might be one or so. What voltage/resistance am i looking for using my new multimeter? Its for friend's zafira but same engine z19dth so can work good with that :-)
    wirral
    49 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Looking for battery voltage
    then with electrical sensor disconnect looking for 0.5-1 ohm on each plug (black wire to engine block red to top of plug)
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    101 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Mine gave this same fault code after replacing all four plugs with pattern ones. Replaced them all again with genuine ( Beru branded) ones and the fault cleared.
    I measured and found that the pattern ones had a slightly higher resistance then the genuine ones. this must have been enough to confuse the control unit.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    3 glowplugs was not in good condition. Only one seems new!
    So replaced all 4 and starts ok. I found injector tubes one was leaking then suddenly spray!!! One tube burst!!! Good job we have a siezed engine handy for spares, replaced it. Jobs a good un! :-)
    Thanks critch for highlighting glow plugs. :-)
  1. Had Windscreen changed now have "general glow plug error"
    By merikiito in forum Engine & Drivetrain
    Last Post: 13th May 2012, 07:52
  2. FAULT CODE HELP: p0380-08 glow device general error
    Last Post: 19th November 2011, 17:28
  3. P0380 - Glow Device Circuit Low Voltage
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 5th March 2011, 01:13
  4. Glow plug general error p0380-08
    By keith_johnson1967 in forum Engine & Drivetrain
    Last Post: 27th June 2010, 19:16
  5. P0381 Glow Device Circuit Low Voltage
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 13:09
vectra c 1.9 glow plug general error
glow plug general device error
glow device circuit general error
