Thread: intermittent dials
    Oct 2012
    staines
    Vehicle : Vectra c
    Trim : Saloon
    Engine : 1.8
    Year : 2002
    Mileage : 101000
    Default intermittent dials
    I have a 2002 vectra c 1.8 ls for the last couple of weeks iv been driving to and from work as normal but after a couple of mins driving my car shows a spanner and drops all my dials and the battery and abs light come on but I can still drive as normal. is anyone else. having the same or similar problems
    thanks
    Full Member
    South West
    Classic symptoms of a either a dirty ABS plug, CIM connection plug or the CIM itself. Try these suggestions:
    http://www.vectra-c.com/forum/showth...=1#post1414186
    Jan 2013
    North yorkshie
    Same but headlights go intermittently, no cruise, a few more warning lights and car won't start when you go to it most of time. Also cuts out over some bumps.
    problem started exact same as yours tho, tried all quick fixes, abs plug etc. fault code cim missing, £850 quote from stealer so on with replacing cim, wish me luck!!
    Mar 2013
    Colchester
    Engine : 2.2
    Year : 2002
    Having the same problem....All dials die, the trip computer display shows 'F' for all readings, all different lights come up but the car drives and feels normal, then after a while the dials and trip computer come back to life and all lights go out except traction control. Had the AA out twice as the car wouldn't start after this had happened. Also had the power steering fail at one point. its now in with Vauxhall dealer.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    First things to check are always fuse 17 in the fuse box at the end of the dashboard (replace it even if it looks ok as they go high resistance) and as already advised above, unplug the ABS plug, clean the connections and replace it.
  1. Dials intermittent
    By foxyland in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2011, 01:37
  2. Vxr dials mod...?
    By devster24 in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2011, 13:33
  3. 2.2 dti dials
    By MattHD in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 07:09
  4. SRi dials
    By merikiito in forum Parts for sale
    Last Post: 4th March 2008, 20:04
