Thread: Dab aerial seal?
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Default Dab aerial seal?
    Has anyone found a way of repairing / sealing / replacing Dab aerial base without paying £225 to the stealers, bearing in mind mine is held together with electric tape and can’t possibly be repaired or can it??
    Any info will be appreciated….
    Dec 2011
    Seaham
    Same problem as trying to get a seal for the Sat Nav bases.
    Was going to try and cut a new base from a rubber sheet, altough it will not have a lip. I also keep looking at other car aerials hoping to spot a similar sizes one.
    Think it needs to be about 100mm X 55mm.
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    I used Sugru https://sugru.com/ - Resistant to most things and nicely mouldable, and completely waterproof.
    Dec 2010
    chesterfield
    Quote Originally Posted by fistymus View Post
    How do you mould into a seal and make it look professional or at least presentable, I can't reuse mine as it's knackered.
    Dec 2010
    chesterfield
    Quote Originally Posted by Ben50n View Post
    Same here mate, refuse to pay their prices. but have to find a solution.
    I think it might be a good idea to cut a piece of rubber to fit, you can add a lip using black silicon, as long as it looks ok.
    Sep 2012
    Saltburn-by-the-Sea
    Year : 55
    Mileage : 126000
    Make a mould with Timber & a Router with a cove bit fitted, then push the sugru in and let it go off for a few mins before removing from your mould.
    Clean up the inner surface with a scalpel and fit onto the antenna base.
  1. sat nav aerial seal
    By john norris in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2014, 21:59
  2. Aerial base seal gone
    By paul wingnut in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 18:06
  3. Replies: 0
    Last Post: 8th September 2011, 12:29
vectra dab aerial seal
vectra c dab aerial site:www.vectra-c.com
