Thread: Correct power steering fluid for vvt compact EHPS?
    May 2012
    UK
    Default Correct power steering fluid for vvt compact EHPS?
    Hi all
    I need to top up the power steering fluid in my '06 vvt which has the power steering reservoir in the engine bay (at the back of the engine) so I think it has the 'compact EHPS'. The level is about halfway up the dipstick at present, maybe a cm from the max mark.
    Does anyone know the correct fluid to ask for from the dealer? It's a blue/green colour.
    Also is it common for the level to drop? (I haven't owned the car from new so it could have always been like that). This is in relation to an issue I'm having where the steering gets heavier after a few miles from cold.
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    May 2012
    UK
    Quote Originally Posted by decks View Post
    Thanks, I'm trying to use the GM fluid to keep it the same as it's a top up, do you happen to know the OE type?
    May 2012
    UK
    Also I have the reservoir with the built in dipstick on the cap. The Haynes manual says that the notch on the dipstick is the max level, can anyone confirm this is correct?
    Feb 2011
    Selby
    Get it from a Vauxhall dealer - if you give them your registration and/or VIN they'll be able to confirm the type. It's not vastly expensive, but the system isn't meant to need regular checking or topping up. In theory it only needs inspecting every few years.
    May 2012
    UK
    Quote Originally Posted by rich r View Post
    Hi, thanks. Yeah I'm going to call over shortly to get some. I'm the second owner so not sure if the previous owner got it inspected as the car was serviced at an independent. It's maybe dropped a cm from the max level as indicated by the Haynes manual. The car has only 44k on it. The power steering is getting heavier with driving but not losing the assistance completely.
    The Haynes manual says the max level is indicated by a notch on the dipstick, there isn't a minimum level indicated so it's hard to know if the fluid is causing my issue! Trying to track it down to avoid paying the dealer a diagnostic fee...
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I'm sure its central hydraulic fluid. Halfords sell it http://www.halfords.com/webapp/wcs/s...egoryId_255219 but obviously the stuff decks found is way cheaper
  1. Power steering fluid.........
    By Sway in forum Engine & Drivetrain
    Last Post: 18th December 2012, 20:06
  2. Power steering fluid
    By dittohead in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 12:50
  3. Power Steering Fluid
    By jrwilshire2003 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd February 2010, 16:16
  4. Power Steering fluid
    By Dazbaz in forum Engine & Drivetrain
    Last Post: 21st August 2009, 17:03
  5. Correct Power Steering Fluid ?
    By AirCooledHeaven in forum Engine & Drivetrain
    Last Post: 26th June 2009, 23:32
vauxhall vectra power steering fluid top-up
