Thread: Dimming headlights
    Jan 2013
    west midlands
    Default Dimming headlights
    Headlights on my 2008 vectra dim when i turn the steering wheel and the interior light flickers , there also seems a lack of power when driving.Any ideas ??
    6 Post(s)
    Quote Originally Posted by liam51 View Post
    Headlights on my 2008 vectra dim when i turn the steering wheel and the interior light flickers ??
    Perfectly normal. The PAS pump is electrically powered and takes quite a bit of juice out of the battery. It shouldn't do it, or hardly noticable when driving and you've got the engine revs up a bit.
    Can't answer your other question, but you might get some replies asking what engine, etc. Yes, people can look at your profile to find it (if you've included it), but not everyone knows that to find the info.
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    As Big Dave said, i've measured the PAS taking 70amps briefly.
    Replacing the battery with the biggest one you can fit in the battery box helps, especially if it's the original battery.
    What engine and mileage??
    Regular Member Bethan39's Avatar
    South Wales
    Sorry to butt in on your thread but i have something similiar when i had my Tid display in no flickering but since i've changed to a Gid everytime i turn the steering wheel it flickers like mad anyone?
    Feb 2011
    Selby
    Exactly the same - at low engine rpm (<1500rpm) the alternator isn't producing enough current to supply the power steering pump and all the other electrics fully, so the voltage dips a little. A bigger battery and ensuring the battery and alternator connections are in good condition helps reduce the impact though. It's more noticeable with a GID simply because it's larger backlight draws more current than the TID backlight.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Check the ground/earth (black!) connection. Sometimes a bad ground in the circuit can cause issues too.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Quote Originally Posted by stevoxsi View Post
    Think there is a thread/how2 on upgrading the earth cable in the engine compartment, which does also help.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    You can get a 019 battery in there quite easily
    Jan 2013
    west midlands
    Thank you for that mate , i was beginning to think there was a major problem have still booked it in to the garage anyway to try and solve the other issues cheers ........... Liam
    Jan 2013
    west midlands
    Its a 1.8 SRI 2008 with 48 k on the clock.
  1. dimming mirror
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 01:38
  2. Led into the dimming mirror
    Last Post: 21st February 2012, 13:46
  3. dimming..
    By kenp in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2010, 21:46
  4. Dimming mirrors...
    By Russi666 in forum Bodywork & Interior
    Last Post: 27th September 2008, 19:59
  5. Dimming/Flickering Headlights
    By The-Bandit in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2008, 09:09
