Thread: vectra 1.9 cdti auto(150) non starter
    Sep 2010
    Plymouth
    Engine : 1.9 CDTi 150
    Year : 06
    Mileage : 250,000
    Default vectra 1.9 cdti auto(150) non starter
    this morning i went to start my car, dash lights all light up, turn the key to start and nothing, just a faint, relay click!!
    Took the starter off the car, stripped it and cleaned it, checked all the contacts, tried it by putting it over a battery and it engaged.
    Fitted it back on the car, tried it again and nothing, still only the relay clicking, took the relay out, have looked over it and there in no signs of burning out.
    What else can there be on this car that will cause this issue, i have power at the starter as i have checked the wiring (and even got more than a little spark)
    Any help would be appreciated the car is immobile and as its an auto it cant even push start
    argyll, scotland
    have you tried to jumpstart it ?? mine has the same problem as yours gonna try a new battery first
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    yes, tried a jumpstart, the battery is pretty new but i figured it as worth a punt, still nothing
    Thanks for the suggestion though
    argyll, scotland
    so it still didnt work with jump leads attached ? im waiting on a new battery arriving this morning ill let you know if it sorts my problem
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    i think i have got to the bottom of it, but would appreciate if someone could confirm my thinking is correct:
    Fuse 2 had blown, this is the starter fuse, as a 'bodge' i by passed it, the solenoid now clicks but will not engage the starter, so the starter is potentially fubar'd
    I believe the fuse blew this morning because it was cold, the starter jammed and drew more current than the fuse could supply.
    I still dont understand why when i put the starter over a battery it engaged
    argyll, scotland
    just put a new battery in mine there and started first time although i do now have the engine symbol staying on the dash hopefully a good run will clear this
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    battery voltage is about 13v after i have been messing about with trying to get it going.
    it had a new alternator and battery not long back, the alternator capacitor failed and fried the battery
    i have looked at this http://www.youtube.com/watch?v=9PWG6Il_ZJI and followed all the instructions step by step, my starter does exactly what it should, but when i put it back in the car it will click once, and then nothing.
    the starter seems to stick against the flywheel, when i turn the engine by hand it will disengage and then if i try again it will click and stick.
    This is really frustrating, i can now remove a starter in about 5 mins where i have done it so many times.
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    With it being auto it is in p or n ain't it?
    Do the vectras have a display on the dash saying what gear there in?
    If so, If you go through the box is it following.
    Ie if it's in P is the dash in P and not R?
    Sep 2010
    Plymouth
    Year : 06
    Mileage : 250,000
    fixed!!!!
    It was the starter all along, there was high resistance in the solenoid, this meant that when you did a bench test it would act like it should work, but on the car it wasnt man enough to do the job.
    A little bit of voltage testing soon establish that it could only be the starter we had
    12.7v @ battery
    12.6v @ power connector on solenoid
    .27V @ the ignition contact of the solenoid
    The giveaway was when we did a resistance, i had been advised to see about .3v-.5v i was getting 2 volts
    Thanks for all your help guys
  1. Auto transmission starter motor
    By Lao in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2012, 13:41
  2. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
  3. how much oil do i put in my auto box, vectra 1.9 cdti
    By matthughes73 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2009, 23:10
  4. Looking @ Buying A Vectra CDTI (150) Auto
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 16:49
  5. 150 CDTI VECTRA AUTO Design or SRI
    By neilmc in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2007, 20:46
cdti 1.9 150 solenoid resistance
