Thread: help
    Regular Member multi.123's Avatar
    Aug 2012
    liverpool
    Vehicle : vectra vxr
    Year : 08
    Default help
    hi everyone right my problem is i got my vec c a few months ago now a few things had already been done its a vec c 07 vvt but has had vxr upgrades and i have fitted some stuff along the way.... back to my problem..
    The sports switch it has the plug thing behind the button but no light or action from pressing it how do i remove the plug behind the button to see whats going on or so i can wire it in for me to have the light on thanks for any help Matt.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    @andy.l or @plasma are probably the guys to speak to mate
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    you wont get the sports button to actuall function unless you
    retro fit the cdc/ids but i dont think this was available for the vvti engine
    the switch will not light up unless you have the above fitted but you
    can have it to just illuminate like the rest by adding the rest of the ground
    wire to the multiplug behind the kick panel
    Aug 2012
    liverpool
    Year : 08
    Just looking for it to light up tbh I dont know how many other things have been done to this I need someone to have a good look at it to see what else has been done as am just a beginner with this am fine with hids drls styling mods but this is out of anyin I know ha cheers for the help guys
    How can I take the sports button out to see the back of it for wires.... can take pics if needed thanks again guys
    Matt
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    I've just wired my sports switch up to light up,, last week in fact.... Basically,, remove the screen and heater vents in the centre, and pick up 1 grey/yellow wire and 1 brown wire... Yellow/grey is power , brown is earth... I used a floppy disc drive plug connector which I bought from maplins for approx 2 quid... At the rear of the sports switch there are pins,,, you only need to use pins number 2 and 5... The brown wire you picked up from the loom needs to go to PIN number 5 and the grey/yellow wire you picked up goes to PIN number 2.... The plug I got from maplins sits across 4 of the pins in the rear of the sports switch, as long as it sits across pins 2-5 it's fine... And it really is as simple as that tbh...
    Sent from my iPhone using Forum Runner
    10 Post(s)
    Trim : elite
    Year : 2011
    if youve got the red plug behind the blank then it will already be wired into the illumination circuit and earthed out
    so it shud just illuminate automatically wen you put the side lights on.
    Admin plasma's Avatar
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    as per what AndyL said. Are you looking for the button to light up when you push it to activate sports mode? This MAY be possible by activating CDC in the BCM module, but it will still not do nothing other than light up if that.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Aug 2012
    liverpool
    Year : 08
    dilan was that just to make it light up or does yours do anything ?...... andy.l ill take a pic now to show you what i have am just looking on it to light up with the rest of the dash i dont think its ment to do anything apart from that to my knowledge think its just there for looks
    Aug 2012
    liverpool
    Year : 08
