Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Starter Motor
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Starter Motor
    How long would it take a garage to change a Starter Motor on a Vectra 1.9 CDTi 150 and how how would I expect to pay?
    Dave
    Dec 2012
    north west
    Should imagine a decent mechanic could do it within one hour, as for cost, ask them what their hourly labour charge is. hth.
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    The guide garages use says 1 hour. Took me slightly longer as I've never done one on a vec c, should be around £80ish.
    Sent from my Xperia S via Forum Runner
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Is the Starter Motor for a Vectra CDTi 150 Automatic the same as for the CDTi 150 Manual Transmission?
    Dave
    Jan 2013
    Chester
    Vehicle : Vectra estate xp cdti
    Trim : Sri xp
    Engine : 120 cdti
    Had ours changed on a 120cdti,35 mins from start to finish
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by Sebastian B View Post
    Dave
    No - they use a different starter motor
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    I have been having issues with this colder weather, when I start the car it appears to drain a lot of amps from the battery, the lights on the dash dim considerably and the ABS and Anti Skid lights come on for a moment when the car finally starts, appears to be low amps.
    The battery was brand new in August 2012 and started doing the above in October 2012, thought there was a problem with this battery and was replaced in November 2012. It was fine for a while but started doing it again. I don't think the garage will issue another replacement battery.
    I have had the car 5 years and never changed the starter, could this be draining more amps than it should an causing the above issue?
    Dave
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Anybody?
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    Sounds more like alternator to me, starter would ether start or not start your motor.
    Sure someone on the evening shift will be able to advise shortly! :-)
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    The voltage on tick over is 13.2 so I dont think it is the alternator.
    Dave
  1. Starter Motor?
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2012, 15:18
  2. Starter motor help.
    By 123rado in forum Engine & Drivetrain
    Last Post: 6th January 2012, 21:30
  3. Starter motor
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:40
  4. Starter Motor
    By Steeev in forum Engine & Drivetrain
    Last Post: 15th September 2008, 16:56
