Thread: snowflakes alloy welding
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    Default snowflakes alloy welding
    does getting a snowflake alloy welded up mean they are just as secure as original or are you just on borrowed time with it looking to buy some 19" but they have two cracks in ????
    cheers lads
    Dec 2011
    Seaham
    Personally I wouldnt touch a wheel that has been welded. You will never truly know how well the weld has penetrated the metal.
    Also, you can often find that the welding itself can cause other weeknesses due to the heat in a localised area.
    Full Member
    South West
    One of my Snowflake tyres started to deflate slowly and it was caused by a crack in the wheel. had it welded and was still going strong after 20k miles until i sold the car.
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Depends on how the weld is done. Had my wheels repaired professionally the cracks v out and filled and welded at the proper temperature and was told the actual weld will be stronger than the rest of the wheel ran the wheels on my old heavy signum v6 cdti with out any issues
    Dec 2011
    liverpool
    6 Post(s)
    i have seen yours mate if you were closer i would of had them off you but its getting them from scotland thats my problem
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    If done correctly to the correct weld procedures with the correct filler material the weld will be stronger than the parent material.
    The tricky bit is finding someone who has the skills and knowledge and equipment to do it correctly.
    Dec 2011
    Seaham
    There is an obvious design weekness in the wheels. I heard that some of the BMW wheels were also prone to cracking. BMW have always denied there were a problem with those wheels. Has Vauxhall ever admitted there was a prolem with the snowies??
    Trim : vxr
    Mileage : 31000
    Our bl..dy road surfaces don't help with all the potholes damn cheek the amount we pay for road tax
  1. Welding
    By Keithy in forum East Scotland
    Last Post: 17th November 2010, 12:24
  2. Alloy welding?
    By L11Marc in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2010, 18:27
  3. Alloy Wheels - Snowflakes 19 "
    Last Post: 20th January 2009, 19:33
  4. Welding an alloy, is it safe?
    By James C in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2007, 19:56
https:www.vectra-c.comforumshowthread.php179335-snowflakes-alloy-welding
vectra snowflakes welded
welding alloy wheel cracks bmw forums
