Thread: sump plug removal
    Jan 2012
    Silverstone village
    Default sump plug removal
    Hi , I went to change my oil today but got to the sump plug and found it mashed and a few marks as though someone had attacked it with a hacksaw.
    What is the best way to remove weld on a nut and then refit a new plug ?
    Engine : 1.9 CDTi
    Chisel it on an edge or use an Irwin bolt remover.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Irwin bolt removers ....
    removed many a rounded plug with them.
    hull
    I would take it to your local indy garage mate, they'll have a tool to get it moving, wouldn't try the chisel though as the sump plugs are like chocolate
    Jan 2012
    Silverstone village
    Cheers guys, think I will leave it to the garage, as it will be allot easier when on ramps.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    replaced mine with a standard hex type from Halfrauds, i don't like the idea of having a torx sump plug
    Middlesex
    Trim : SRI
    Mileage : 100k
    I believe the OP has a cdti - so will be a HEX type
    they have a tendancy to be FT!... Irwin all day long will remove in seconds. if your close to Ashford Middlesex I can do it for you.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Torx bits are fine if you use the right bit size.. iirc its a 45
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Quote Originally Posted by Signum-Steve View Post
    true but not if the gimp you bought the car off did not have the right size and shafted the plug...
    Regular Member stret's Avatar
    Oct 2012
    east midlands/westmidlands
    27 Post(s)
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 16v 225bhp
    Year : 54
    Mileage : 150k
    i went to service mine yesterday and had same prob luckily i got some good quality mould grips locked them on few blows with dead blow hammer and it was off then went to local motor factors to get a new plug for a £5
  1. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  2. Sump plug removal
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 15:33
  3. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  4. sump plug
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 7th January 2011, 22:33
  5. Sump Plug ?
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2008, 14:59
vectra c using hex sump plug www.vectra-c.com
vectra c sump bolt size www.vectra-c.com
