Results 1 to 10 of 13
Thread: screen swap
    Regular Member rubberduck*2012's Avatar
    Dec 2012
    stanhope
    Default screen swap
    i have managed to damage my screen in the car is it possible to buy a new one and just plug and play with it
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes you should be fine as yours is a preface bud make sure you have a passcode in case your HU asks for the radio code don't think it will though
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    What screen/radio combo do you currently have fitted?? A photo will help if you can do it.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    I have a unpaired TID screen here if needed
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by rozzer2006 View Post
    i think yours is full can as you had my GID the op has a half can which isn't comparable.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Oh well lol, ive moved on from that now got a navi and CID lol still got the GID tho, in blue
    Dec 2012
    stanhope
    whats the differnce between al thes gid,cid,tid,std screens i have no radio at the moment but putting a double din sony head unit in, have had the car a month and its been in the garage over xmas for waterpump, am not having any luck lol
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    TID has 2 buttons, and displays Time, Radio Station and outside Temperature
    BID is a mono (orange), and I think it can only display the same info as the TID.
    GID is a mono (orange) screen and can display more info, such as fuel consumption, and can be used with sat nav.
    CID is colour screen, used with sat nav. The Holy Grail.
    If your fitting a Sony Head Unit, then whatever display you have you will have to set the Time and Date manually on it and you will only be able to control it via the steering wheel controls.
    The above info is, I think, 100% correct, but if not I'm sure someone will correct it.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Quote Originally Posted by rubberduck*2012 View Post
    I take it u changed the timing belt if it has one that is??
    The BID shows consumption although its a bit brief, if ure havin a aftermarket unit in the GID is best or u could go for the BID. What year is urw car??
    Dec 2012
    stanhope
    It has a chain but rattly when cold gonna give it a good service and see if the rattle stops, if not al change the chain i have receipts that say it was change feb 2011 and i shall stick with rhe gid
  1. Definitive answer on stereo and screen swap?
    By Munnzie in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 14:32
  2. colour screen, straight swap???
    By Big Red in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2012, 20:29
  3. Swap mono screen for colour in Signum
    By peterc2609 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 13:30
  4. display screen swap
    By jamesr in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2007, 23:48
