Results 1 to 10 of 25
Thread: Vectra estate 3.0 V6 SRi, diesel. 2007. Cutting out/not starting! ...
    Jan 2013
    Wrexham
    Angry Vectra estate 3.0 V6 SRi, diesel. 2007. Cutting out/not starting! ...
    Hi, I'm new to this forum, I hope you can all help me-I'm at the end of my tether with my vectra!! I only got it 4 weeks ago. It's been cutting out when slowing down and revs are low, eg. When I put my foot on clutch to change gear at roundabout etc. sometimes it will start straight back up, sometimes it won't start at all and sometimes it starts but won't rev when the accelerator is pressed and then it just dies after about 5 secs. If driving on motorway it doesn't cut out due to higher revs but will chug and you can tell if I was driving at a slower speed it would've cut out. I've had 2 diagnostics done on it, 1 was fine, 1 said low voltage to relay (relay "peg" was changed but problem remains). I don't know what else to do!! I've been booked in to have it looked at at a garage on Tuesday but not sure what they'll say with no codes coming up!!! Any help would be amazing!! Thanks in advance!!
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    You need someone that's going to take time other than look at codes
    Throttle position sensor voltage would be a start. Fuel pressures. Air intake.
    theirs a lot than affect
    needs a full data read.
    Then needs some form of log as the faukt occurs.
    Jan 2013
    Wrexham
    Ok, I'll see what this garage says but most people these days aren't willing to spend their time on it!! Or it costs alot of money if they do!! And most aren't very familiar with my make car! Nightmare!! Thx tho
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Their only not prepared to spend time because their not sure what their looking for.
    majority of garages just code read then throw a part at it.
    ask them to give you some info on fuel pressure. MAF reading and MAP reading along with throttle position percentage and voltage at various revs
    Regular Member sir pingu's Avatar
    Jan 2012
    Klarup DK 40 cm away from Keyboard
    Vehicle : Vectra Estate Irmscher 3.0 CDTI
    Engine : Z30DT
    Year : 11 06
    Mileage : 301000 KM
    Try to search the words SCV (Suction Control Valve) with the search engine, because it looks like the symptons off that.
    And post in the sub forum - Y and Z30DT specifik.
    Cumbernauld, Scotland
    Quote Originally Posted by sir pingu View Post
    Not with those symptoms it not
    Quote Originally Posted by Katie View Post
    Where did you obtain this car from?
    What garage are you using?
    Have they ever carried out repairs on a Z30DT engine (3.0 V6 CDTI)
    Let's just make sure we understand this correctly (as you have posted in one long paragraph)
    When you turn on the engine, does it rev on idle correctly?
    What are these idle revs?
    When you start off, let's say accelerating to 50mph, typically at what revs do you change gear?
    What happens when you change gear?
    When driving at a constant speed, let's say 50mph, can you engage Cruise Control?
    Will it hold this speed?
    What gear are you in when driving at this speed?
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    think you need to re read the symptoms yourself before advising others.
    Scv blockage is not with the symptoms described by the op
    Jan 2013
    Wrexham
    Hi guys - thanks for all your suggestions...I'll look them all up and ask the garage about what has been suggested. M8internet, here's my answers :-) :
    Bought it from a car dealer in Birkenhead. They are trying to sort the problem and looks like they'll pay under warranty but they did mention about a £100 maximum per claim....
    What garage are you using? I'm using a local garage in Wrexham, no Vauxhall garages or anything.
    Have they ever carried out repairs on a Z30DT engine (3.0 V6 CDTI)? Not sure about this - I could call up and ask. I'm not sure it's anything to do with the engine as such as theres no major codes coming up...could well be wrong though - I'm no expert!!
    Its hit and miss - if she's behaving its normal. If not, the revs are quite low and they gradually die down until she stalls.
    What are these idle revs? the revs are ususally 700
    Usually change gear at around 2500 revs (usually keep the car at or just under 2000 revs)
    Depends if I'm changing up or down. If I'm slowing down (if shes playing up) she'll just stall. No jolt or anything just smoothly cut out. I seem fine when increasing speed.
    When driving at a constant speed, let's say 50mph, can you engage Cruise Control? I think so - don't use this feature much but when I have its been fine.
    Will it hold this speed? Holds its speed but when on a motorway if she starts playing up she'll drag and accelerate (feels like mild "kangarooing"!!!) for a few miles then it'll pass for a while.
    What gear are you in when driving at this speed? when I drive 50mph I'd say I'm in 4th. I know I keep the revs at or just under 2000.
    Thanks!!! :-)
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    When was service carried?
    What garage was it you bought it from?
    100 max will get you the square route of zero on that engine.
    a simple map sensor is £84 so add labour your over and that's one of the most accessible sensors bolted to engine
    egr valve is double that. Plus couple of hours labour.
  1. For Sale: Vectra VXR Estate 2007 Arden Blue
    By gizmo10119 in forum Cars for sale
    Last Post: 31st December 2012, 17:16
  2. 2007 Vectra Design 1.8 vvt electrics / engine cutting out
    By mk2cav in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2012, 20:29
  3. 1.9 diesel vectra not starting
    By vectrahunter in forum Engine & Drivetrain
    Last Post: 17th June 2012, 20:41
  4. 2.0 vectra c diesel cutting out & lack of power? :(
    By redrhino in forum Engine & Drivetrain
    Last Post: 25th March 2012, 00:35
  5. Vectra 2007 1.8i Estate - Do the heated mirrors really work?
    By Mike McGibney in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2010, 19:22
vectra 3.0 v6 special cutting out
vecfra 3.0 cuts out
vauxhall signum 3.0 v6 cdti starts then cuts out
3.0 cdti vectra cuts out at 90c
vectra c v6 diesel estate 2007
