Results 1 to 3 of 3
Thread: Vectra 1.9 CDTI p0400-04
    Jan 2013
    Glasgow
    Default Vectra 1.9 CDTI p0400-04
    Hi everyone,
    I'm new to this website as I have struggled with my Vectra 1.9 CDTI(06) for a while. When I bought it everything was fine but eventually it developed a fault. After reading many threads I but EGR valve as it seemed obvious and not too expensive. Unfortunately I bought some Chinese after-market part but on his website it said Vauxhall part so I returned it to him. Now I got my old valve and the most annoying is kangarooing and I still don't know whether the valve is faulty. I took some readout form diagnostic device so that might tell someone what is wrong. When I press active button in EGR SOLENOID test menu nothing happens. PLease help!
    Measuring blocks information:
    Battery Voltage 13.8 V
    APP at Idle Position (Accelerator Pedal Position) Active
    APP Sensor 1 (Accelerator Pedal Position) 0.96 V
    APP Sensor 2 (Accelerator Pedal Position) 0.47 V
    Calculated Pedal Position 0%
    Desired Engine Idle Speed 850 RPM
    Engine Speed 877 RPM
    Camshaft Speed 425 RPM
    Idle Speed Modified No
    Calculated Air Flow 52 kg/h
    Mass Air Flow Sensor 52 kg/h
    Charge Air Temperature 40 °C
    Charge Air Temperature 2.44 V
    Fuel Temperature 32 °C
    Fuel Temperature 2.81 V
    Barometric Pressure 101 kPa
    Barometric Pressure 3.96 V
    Boost Pressure Command 104 kPa
    Boost Pressure 103 kPa
    Boost Pressure 1.66 V
    Pulse Ratio Boost Pressure Solenoid Valve 75%
    EGR Position Commanded (Exhaust Gas Recirculation) 100%
    EGR Pulse Ratio (Exhaust Gas Recirculation) 10%
    Throttle Position PWM Servo Signal 0%
    Desired Common Rail Fuel Pressure 30.40 MPa
    Common Rail Fuel Pressure 30.10 MPa
    Common Rail Fuel Pressure 1.15 V
    Rail Pressure Control Solenoid Valve PWM 17%
    Rail Pressure Control Solenoid Valve Current 0.39 a
    Fuel Metering Solenoid Valve PWM 33%
    Fuel Metering Solenoid Valve Current 1.17 a
    Glow Time Relay Inactive 12V
    Diagnosis Glow Time Relay Inactive
    Glow Time Telltale Off 12V
    Vehicle Speed 0 km/h
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Clean/Replace the EGR valve
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    pm ed you your inbox is full
  1. Keep getting trouble code: P0400-5A, on SRI CDTI 150
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 18th January 2013, 19:38
  2. P0400 help please 1.9 Cdti
    By AOL in forum Engine & Drivetrain
    Last Post: 12th July 2012, 20:11
  3. p0400
    By farley2708 in forum Engine & Drivetrain
    Last Post: 10th February 2012, 22:54
  4. Vectra c 2.0 DTI dtc P0400.
    By jtg in forum Troubleshooting
    Last Post: 19th July 2011, 21:22
  5. P0400 - 2005 cdti 150
    Last Post: 14th June 2009, 19:00
2005 vauxhall vectra 1.9cdti p0400
vectra c po400-04
p0400 vectra 1.9 cdti
opel vectra 1.9 cdti p0400
