Thread: HID knowledge required
    Sep 2011
    lewes
    Engine : 1?? - Teapot mapped
    Mileage : 125000
    Default HID knowledge required
    Installed my HID kit this morning after getting the replacement ballast. Both bulbs ignite with the ignition off however if I start the car the bulbs turn off and will not come back on.
    Do I need to get Xenons activated or fit cancellers?
    Car is a full canbus pre-facelift.
    Regular Member krazylegz's Avatar
    South Shields
    If i'm reading this your saying you turn on your headlights then start the car? if so try starting the car then turning on the lights.
    Mine was still ok without xenons activated, only noticable difference is they now don't flicker when turned off due to the car doing it's check on the bulbs
    Sep 2011
    lewes
    Mileage : 125000
    I started the car, then turned them on. Both sides did a little flicker then they went off. Sorry I didn't word it very well
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Try turning the switch from sides to hids very slowly see if they fire up... One of mine has started going and does similar, but it is 3 year old, maybe faulty ballast?
    Regular Member MarkV6cdti's Avatar
    Sep 2011
    Northampton
    Vehicle : Vauxhall Signum
    Trim : Deselite :-)
    Engine : 3.0 V6 CDTI
    Mileage : 130,000
    I had the same problem had mine fitted yesterday, engine off, fine and when I fired her up flickers and off.
    Had my xenon enabled through opcom and all fixed.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Ohhh my God
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Quote Originally Posted by phil67 View Post
    Ohhh my God
    Ha ha ha pmsl
    Northampton
    Engine : A20DTH
    Mileage : 88000
    It was Vauxcom not Opcom
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The reason the HIDs do not work is that they are getting a pulsed current. They will work when the engine is turned off as the current does not become pulsed until the engine is started.Halogen lights require a pulsed current which makes them last longer and stay brighter. HIDs do not need a pulsed current and therefore you need to activate "Xenons" in the under bonnet ECU which turns of the pulse and also the bulb check.
    HIDs will not work unless you use additional hardware or activate them
    Sep 2011
    lewes
    Mileage : 125000
    Quote Originally Posted by MarkV6cdti View Post
    Annoying isn't it!!
    Quote Originally Posted by merikiito View Post
    Thanks for that explanation
  1. May already be common knowledge
    By Critch in forum Engine & Drivetrain
    Last Post: 14th December 2012, 20:06
  2. Hid kit knowledge please
    By anthonychall in forum Styling
    Last Post: 4th November 2010, 19:01
  3. Anyone Have any Knowledge of this...
    By chrisschild in forum General Chat
    Last Post: 3rd July 2008, 18:31
  4. Anyone with Merc Knowledge.
    By kitchpoo in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2006, 21:52
  5. Police knowledge required...
    By Harry in forum General Chat
    Last Post: 26th May 2006, 20:31
