Results 1 to 10 of 20
Thread: 120 cdti cold start cranking
    Regular Member Slammedorion's Avatar
    Mar 2012
    cheshire
    11 Post(s)
    Default 120 cdti cold start cranking
    MY07 Vectra CDTi 120 is taking a good 5-10 seconds before it fire on first cold start only, bar first start in the mornings its perfect.
    It seems to have developed this fault since I changed the fuel filter housing and thermostat housing?
    I've since been back Vauxhall and they've swapped the fully built up housing for another to try and cure this issue.
    But it doesn't seem much better.
    This morning with is being frosty it has been even worse to start.
    Reading through other threads someone has mentioned it could be the temp sensor? ( Pressuming the one in my new thermostat housing??? )
    Need help guys.
    Since buying the car its been pampered by me, since October 2012 I've treated it mechanically to 3 oil changes, k&n panel filter plus mod, cambelt, tensioners, aux belt, water pump.
    Glow plugs, pipework to boost solenoid, boost sensor clean up.
    Fuel filter housing, thermostat housing, tunning box.
    Now its kicking me in the teeth, I've done all the above for reliability.
    Dec 2012
    Midlands
    Mine is exactly the same, and I'm not sure what to do. What oil have you got in it? Might do the leak off pipes as its a quick and cheap job.
    Mar 2012
    cheshire
    11 Post(s)
    Can't remember what oil I run, its whatever CES give me, currently using drive tech/ master??? ( Its made by mobil 1, just with a different label on ). Im not keen on engine flushes, and since the last owner hasn't really bothered with owt on this car, my pet hate is dirty black oil, theres no need for what it costs in parts, it protects the engine. So I've been dropping it every 2 months to get it cleaner in there.
    I start to go to a 4-6 month oil change after the next one.
    I have thought about leak off pipes.
    But when it does start it starts cleanly, no juddering or missfire like syptoms.
    I think its a fuel problem myself. But its getting me down now.
    Mar 2012
    cheshire
    11 Post(s)
    Searching through more threads I've come across a post about faulty temp sensors causing poor starting from cold.
    Although I've just fitted and new thermostat housing with new sensor from Vauxhall, I suppose there is the odd chance of a bad'en???
    It's saying to disconnect sensor and try starting it. If it starts better then I know the sensor or wiring could be at fault.
    I'm not using the car tomorrow, but the misses is.
    If I disconnect the sensor tonight, and let her use it tomorrow with it disconnected there won't be any running issues will there?
    I can cope with a drop in mpg and elm on for a day while I trial this.
    Mar 2012
    cheshire
    11 Post(s)
    Well its parked up for this evening, removed plug from water temp sensor. Fans are on constant when running but its not a issue for a quick cold start test before I bike to work in the morning.
    Fingers crossed it fires straight away and I can try another temp seonsor.
    Its starting to snow here too.
    Any other ideas if this don't sort it? im hoping its this sensor. Im getting sick of the fault finding.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    It seems common on the CDTi 120 for cold starting issues. Mine takes anything from 1 to 6 seconds to start from cold. Fine any other time and drives like new
    Mar 2012
    cheshire
    11 Post(s)
    Its battered my head, it was fine with the non-working temp gauge, and un serviced lol.
    Start to get on top of the jobs and it kicks you in the teeth.
    I'll get there with it.
    Nov 2010
    East Midlands
    Trim : design
    Starter motor sluggish and not turning the engine over fast enough?
    Mar 2012
    cheshire
    11 Post(s)
    Na, it cranks over like a good'en.
    Nov 2010
    East Midlands
    Trim : design
    Mine did - but the new one was twice as fast and cured the starting problem
  1. 1.9 cdti knocking cold start
    By valleyboy in forum Engine & Drivetrain
    Last Post: 3rd January 2013, 23:23
  2. cdti cold start cured.
    By john1 in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 23:26
  3. vetra 1.9 cdti cold start issue
    By all vaux in forum Engine & Drivetrain
    Last Post: 21st December 2011, 20:33
  4. Cdti 120 cold start
    By Paddy in forum Diesel Engine related
    Last Post: 12th November 2011, 02:07
  5. CDTi 16V Cold Start
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2005, 11:19
