Thread: EGR Cooler Blank Question
    Dec 2012
    Chatham
    Default EGR Cooler Blank Question
    Hi, I have a 120 cdti and I think that the pipe that runs from my Egr cooler to the egr valve is split as i have exhaust gases in the cab at standstill and also a high pitched whistling when accelerating under load at 2000rpm plus (no apparent affect on the car other than the noise). i have purchased an egr blanking plate off of ebay my question is could i blank the end of the pipe off the cooler end rather than the egr end to save me having to pay £100+ for the egr cooler pipe?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    120 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    I assume you mean where the egr pipe is attached to the exhaust manifold. I seem to remember this looked the same size/shape as the other end. If the blanking plate fits in the alternative location and you use two new gaskets, I see no reason why not.
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I recommend blanking both ends when mapping out the egr as the cooler can be ruptured.
    Dec 2012
    Chatham
    would i need gaskets on the blanking plate then? i didnt think i would as it is alloy? not planning on having it mapped out just blanking and going to put up with the light for the time being
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    No you shouldn't need gaskets - but have a look at this how2 - http://www.vectra-c.com/forum/showth...blanking-plate
    Dead easy to make a blank - just don't drill the holes in the middle if you want a complete blank.
    As said above if you do a complete blanking off you will probably get a warning light thrown up on your dash and you will have to have the EGR programmed out to get rid of the light.
  1. EGR cooler
    By den2712 in forum Engine & Drivetrain
    Last Post: 1st June 2012, 06:56
  2. Oil cooler
    By Dimscreen in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 22:42
  3. Will this oil cooler fit my v6 ???
    By poves in forum Engine & Drivetrain
    Last Post: 5th August 2008, 19:26
  4. 3.2 Oil Cooler ?
    By poves in forum Petrol Engine related
    Last Post: 20th July 2008, 13:31
  5. Oil Cooler
    By IBarfoot in forum Engine & Drivetrain
    Last Post: 17th July 2008, 16:37
vectra c egr cooler blank
Does egr cooler need blanked at both ends
