Thread: 2.0 dti estate 04 plate running problem
    Sep 2012
    Leicester
    Default 2.0 dti estate 04 plate running problem
    i hope someone can help with this one,i found a video on youtube of a vectra doing the same thing as mine,the title is opel vectra c 2.2 dti y22dtr problem.its by 1kircsi and has the opening shot of the inlet manifold.
    Sep 2012
    Leicester
    Sep 2012
    Leicester
    bump
    Regular Member bogbody's Avatar
    Jun 2007
    Peterborough
    Vehicle : Astra
    Engine : 1.6
    EGR wants cleaning/replacing? ???????????
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    No if the engine is hunting as in the video then its the throttle position sensor thats knackered
    Do as the guy does and pull of the vacuum hose only at the other end near the egr ,block off both connection,s the engine will now stabilise .
    This will be a short term fix , but in ther long run you need a new inlet manifold with the tps sensor
    vx dont do the tps by itself so probably best to hunt a replacement from a breakers.
    To buy a new manifold from vx your looking at the best part of £400 but some of the online seelers sometimes get them in stock but they dont hang around very long .
    Seen one recently (late last year for £182 plus vat )so around half price compared to vx
    and still loving it
    Jun 2007
    Peterborough
    Vehicle : Astra
    Engine : 1.6
    ? Garage said that they replaced the EGR on my old (dearly departed) Signum 2.2DTi and it fixed the same symptoms. It was done under warranty so I have no paperwork to check back on. It was 5 years ago now. The fault put EML light on, the engine would hunt, there was no response to the throttle - dead handly if you were trying to turn right onto a busy road. How I didn't get taken roughly from behind that day was a mystery to me!
    I guess getting the error codes read would be the best next step? I though that the 2.2DTi was "drive by wire" so that there is only a TPS on the pedal in the cabin and not one on the engine as in some of the petrol variants?
    Engine : 2.0DTi
    Mileage : 73350
    bogbody .
    some have the tps on the pedal and others as in the one inthe video have it on the manifold .
    in total there are 3 different variants of manifold for the DT1 engine,s
    but one thing i do agree on his have the fault code,s read first before taking any further action
    Rachr ask on here if there,s anyone near you who can assist you in getting the code,s read .
    a stealer will charge you around £70 just to havve the codes read
    and still loving it
    Sep 2012
    Leicester
    egr looks brand new took it out it was very clean but i did it anyway,top part of the inlert manifold replaced this is the one with 2 conectors.tried the unplug of the hose puts the light on and car feels underpowered.this an intermitent fault and sometmes its great,i was told by a mechanic when it does it disconect the airflow meter and it will be o.k plug it back in and it does it gain,he was right.so got an airflow meter and all was good again for 2 days as it is whenever you fit a new part,and then judder starts again always around 2000 rpm area,all the parts came from a breakers,only fault found was bcm had that done at the stealers
    Sep 2012
    Leicester
    first of all thanks for all your help so far.taken egr out today,gave it a good clean up not much soot really,took the grey plastic cover of the end like i said it looks new,BUT and thats a big but,i noticed inside the cover sooty spots,so opening the valve with the lever checked for side movement in the valve itself and there is,could it be drawing air in through the guide????
  1. 56 Plate vectra 150 CDTI running probs !
    By ajr in forum Diesel Engine related
    Last Post: 28th December 2010, 22:43
  2. Signum starting and running problem
    By DanC in forum Engine & Drivetrain
    Last Post: 24th February 2010, 12:58
  3. cold running problem
    By rave5 in forum Engine & Drivetrain
    Last Post: 2nd December 2009, 10:32
  4. 2.0 DTi Running Problem
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 18:06
  5. 1.9 CDTi 150 running problem
    By djr69uk in forum Engine & Drivetrain
    Last Post: 6th May 2008, 23:07
vauxhall vectra 2.0 dti 04 throttle position sensor issues
