Results 1 to 10 of 13
Thread: Stuck in 1st gear
    Sep 2012
    North Wales
    Default Stuck in 1st gear
    My poor 1.8ls (52 reg) has been sitting patiently on the drive while I've been using the wifes car.
    Just gone to take it for a run and found that everything was fine apart from it being stuck in 1st gear !!
    The car has been stood for around a month and was left in 1st gear. Now I cant get the dam thing out of 1st. Clutch and everything else seems fine.
    Any ideas?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Take the gear linkage cables off at the selector (gearbox) and see if you can move it out of first gear manually. Sounds like a gearbox fault.
    Sep 2012
    North Wales
    Cheers for that. Will give it a go later.
    The gearbox and clutch have been sweet with no issues so its a bit of a shock to get this.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    does your clutch feel normal and was it parked on hill?
    Sep 2012
    North Wales
    Clutch feels fine and I could drive round in 1st no problem.
    Car was parked on level ground. I just thought leaving it in 1st with the handbrake off would prevent the brakes sticking.
    Sep 2012
    Bedfordshire
    You may have tried both of these already, but if not give the following a go:
    1) Put something in front of front wheels (few bricks, bit of wood, ramp if you have them) then start the car up and try rocking it forwards onto the bricks etc, then letting it roll back (use the clutch to do this). If it is any sort of stiction in the gear train that will loosen it (Dan has touched on that re. the hill)
    2) Leave the engine idling for 10 minutes to see if warming it up helps. You'll need to keep your foot on the clutch of course!!!
    If still not working, perhaps try dribling a bit of PlusGas where the gear selector mech entrers the gearbox, leave to sit for an hour then start trying to work it loose.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Will it move out of first gear with the engine off? Sounds like a gearbox issue
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    Quote Originally Posted by mlbertes View Post
    Any ideas?
    what mileage has the car done ?
    Sep 2012
    North Wales
    Hi guys, thanks for your comments.
    I've not been able to do anything on it for the past week due to work commitments but this weekend is crunch time.
    The car has done 167,000 so I was expecting the gearbox to give up the ghost but the car drives so sweet that I was hoping for a few more miles.
    \it wont move out of 1st at all even if the engine is off. As for the rocking I will give it a go but Im expecting a gearbox change sooner rather than later.
    Sep 2012
    North Wales
    UPDATE: thanks for the great advice, much appreciated. I removed the battery and tray then had a play with the gear linkages. This didnt give any clues so I ran the car (with foot on clutch) for 15 mins then gave the gear stick some firm encouragement.... hey presto, the gear stick moved out of 1st into neutral! The stick was stiff at first but after a few minutes it was back to its old self.
    The car is now no longer an ornament on the drive
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
vectra stuck in gear even with engine off
vectra c stuck in gear
vectra clutch stuck in 1st gear
vectra c wont come out of gear
fiat fiorino stuck in 1st gear
opel vectra auto stuck in gear
vauxhall zafira 1.8 stuck in gear
Vectra auto 3 gear www.vectra-c.com
