Thread: Dti sump
    Aug 2009
    n ireland
    Default Dti sump
    Hello I need a new sump on my vectra c 2.0 dti 2002, have a crack so will have to get second hand part , will I need a new gasket or will the old one with care be able to be reused ? Will removing be just a case of all the bolts around the sump or is there more till it ? Anyone done this before ? Any advice appreciated . Regards dwaine
    Jul 2012
    Doncaster
    Pretty sure there seal with gasket sealer rather than a standard gasket. Also it should just unbolt and then wiggle off, if you need a sump let me know as I have a full 2.0 dti for spares.
    Dan
    Aug 2009
    n ireland
    Thanks for the offer of sump but I think I have sourced one local will no next few days ,can anyone confirm what sealant you need to put sump back on ? Or is there a gasket someone must of had to remove a sump before and could confirm ? Any more advice really appreciated. Dwaine
    Regular Member krazylegz's Avatar
    South Shields
    yes mate it's a sealer they use not a gasket. You need to get from Vx but it's not too expensive, done it on my old V6 and it sealed it spot on
    Aug 2009
    n ireland
    Thanks will get sealant from vx thanks
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    You'll need the silicone type sump sealer mate not a conventional gasket.
  1. Sump plug
    By dalecheesy in forum North East RO Vacant - ARO - Vacant
    Last Post: 21st June 2012, 13:52
  2. sump plug
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 7th January 2011, 22:33
  3. crack in sump
    By paulflacky2 in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 30th May 2009, 03:12
  4. Sump plug RRP?
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 21:22
  5. In The Sump!!
    By mitch1965 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 18th August 2008, 09:07
