Thread: Noise on battery?!
    May 2012
    UK
    Default Noise on battery?!
    Hi all
    So I've been trying to track down an issue with my power steering recently and took the car to Halfords yesterday to get a battery check.
    When they put the meter on the battery at idle it came up with 'noise on battery'. He said that the test couldn't be completed as something was draining the battery.
    Has anyone heard of this? I have a multimeter myself, does anyone know the correct setting to use to check the battery voltage?
    Thanks!
    Full Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by Chip View Post
    Hi all
    Thanks!
    why are they checking the battery with the car running ? surely thats just checking the alternator charge rate and not the battery
    May 2012
    UK
    My mistake, I meant not idling - car was fully off! D'oh
    wirral
    27 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    He may just be confused an its doing an alternator ripple test Should be checking battey drain on a static battery Check voltage on multimeter on DC voltsIf your trying to find current draw you need to set it to amps and have the meter in series with batt
    fife
    To check the draw from the battery first you need a multimeter that checks amps then disconnect the neg post from you battery then connect both the leads of your meter one to the post of the battery the other on the neg cable switch your meter on then lock your doors the meter will be reading around 1amp but should drop to 0.05amp when the can system sleeps takes around 30_45 seconds
    If its still reading high start pulling fuses one at a time to see what circuit is draining the battery
    Hope this helps
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
