Thread: Warning bulbs
    Regular Member stuk2000's Avatar
    Horncastle
    Default Warning bulbs
    Hi Guys,
    Just got a Signum 2.0T, 53 plate.
    Noticed that the warning light for having a bulb out is constantly on even though i pressed ok.
    Checked the bulb and it looks ok and cleaned the socket it goes into.
    Anyone know how to get rid of this fault?
    ps it is the rear right brake bulb!
    newport
    i had that on a headlight bulb, every now and again the warning would flash up, even though the bulb appeared to still be working fine, changed it anyway just to be sure and the message hasnt come back on since. if i was you i would change the bulb its saying is out anyway, see if its the same as me
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Change the bulb
    Quote Originally Posted by stuk2000 View Post
    Hi Guys,
    Just got a Signum 2.0T, 53 plate.Noticed that the warning light for having a bulb out is constantly on even though i pressed ok.
    Is it like the Vectra, in that if the normal tail/brake light fails, then the 2nd tail light takes over the role of tail/brake light?
    i.e. have you got 2 tail lights either side of the Signum, and is one of them blown? On first impressions your brake lights look normal, but upon closer inspection the offside brake light isn't at the same level as the nearside one.
    Regular Member bogbody's Avatar
    Jun 2007
    Peterborough
    Vehicle : Astra
    Engine : 1.6
    Agree with Big Dave, the Signum swaps out the faulty bulb and uses another bulb for the brake light function.
    Replace both tail light/brake light bulbs while you have the lamp holder out. I tended to replace any that were going black as well.
    On one occasion I ended up replacing 10 bulbs. All four orange indicator bulbs (following an MOT advisory "too white" - the orange varnish was flaking off) and all four tail light/brake light bulbs because they were going black - one was very dark! Later that day a headlight bulb went so I had to take the headlight out ---- again! I replaced the dip on the other side as well as the bulbs came as a pair on special offer from Halfords.
  1. parking light warning but no bulbs out
    By forde in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2013, 14:21
  2. bulb warning light on....but no bulbs appear blown
    By rjw in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2010, 01:18
  3. Front LED Sidelight Bulbs (No Warning/Error)
    By Kickdown in forum Styling
    Last Post: 12th December 2009, 22:40
  4. Bulb blown warning ON, all bulbs ok??
    By bungle666 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2009, 02:39
  5. WARNING to all changing bulbs
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2008, 12:03
