Thread: 3rd brake light warning
    Jul 2011
    UK
    Year : 06
    Default 3rd brake light warning
    Am getting a error ob screen and light on dash that it not working when I brake can see not on any idea
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Check if tailgate ones working ....
    Jul 2011
    UK
    Year : 06
    Light ones work but middle one isn't it was working before aswel
    Jul 2011
    UK
    Year : 06
    Working again then when turn car off its off again when come to start it up was also flickering as I press the petal then worked again
    Jul 2011
    UK
    Year : 06
    Bump
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Can only suggest it might be worth removing the third brake light from the tailgate and checking that the connector is both clean and secure. Lot of condensation and moisture in cars at the moment, so not impossible it's got damp and the connection could be a wee bit iffy.
    It is possible to remove them without having to take the trim off the inside of the tailgate or anything. A case of using something like a couple of old credit cards to very very carefully prise it out of the tailgate. However, I changed mine on my previous Vectra, and have to say that despite my best efforts, I ended up with a pile of broken plastic bits. Not a big deal, as I was changing it from red to clear anyway. Hard to explain, but on some early Vecs there wasn't even an access hole on the inside of the boot to get to the light, even with the trim removed. Later ones have an access hole in the metalwork to let you actually get to the light.
    Have a read at this too:
    http://www.vectra-c.com/forum/showth...te+brake+light
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
vauxhall vectra c starting third brake light warning
vectra c 3rd brake light warning
Vectra c third brake light warning light
signum 3d brake light error
3rd brake light vectra c working car warnig
vectra c third brake light
