Thread: hesitation when pulling away
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Mileage : 119k
    Default hesitation when pulling away
    Had my car remapped by Dave from mas performance today. Power remap plus dpf and egr deletion from ECU. Then spent a couple of hours gutting out the dpf. All in all im very happy with the results.
    However, ive still got the 2 second delay when putting my foot to the floor from standstill. Pulling away normally, there is no delay. But if trying to pull out quickly, the delay is terrible.
    Im not sure if the problem is to do with the auto box or something else. Dodgy maf maybe?
    Does anyone else with a 150 auto experience the same delay when flooring it from standstill?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Should have asked to change the timings in ecu or update the ecu before remap, saw this on one remap thread on here. The delay is loss of boost then build up. Its inside the ecu.
    Someone will answer this better than i can. Am on iphone so hard to find it for u. :-)
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    No one else experience this problem?
    Apr 2012
    reading
    Yh mine was slow off the mark before remap, have you done air box and turbo vacuum filter removal, how many miles has yours done, take it for a good run on m,way in 3rd blast crap out of manifold, plus I only use shell diesel and v,plus at least once a month, cheers Andy
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Quote Originally Posted by black-gte View Post
    Mines done 86k miles. Ive done the airbox mod but not the turbo vaccuum filter mod. Is there a 'how to' for it?
    Apr 2012
    reading
    Yh there's a thread on here somewhere, I think its under title flat spot, very easy to do, is your swirl bars and manifold working ok
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Yeah they are ok. Bar still attached and moving ok. Ill have a look for that thread and give it a go. Fingers crossed.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I done that, did nothing. Inside was moving freely. Still not solved my issue same as him. :-/
  1. 2.0T Hesitation
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 8th May 2012, 12:48
  2. Hesitation help
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 21:53
  3. hesitation
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 1st April 2010, 18:44
  4. Hesitation
    By Deadman in forum Engine & Drivetrain
    Last Post: 5th July 2008, 18:40
  5. hesitation
    By pogo in forum Engine & Drivetrain
    Last Post: 26th March 2006, 21:06
