Results 1 to 10 of 30
Thread: Poor starting.................but not from cold
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Default Poor starting.................but not from cold
    My 120 CDTi is having problems starting
    It starts fine first ting in the morning, but take it for a run, leave it a while and come back and it takes 3 or 4 attempts to start
    Been reading about and the crankshaft sensor may be the culprit ?
    Anyone know if its difficult to change, or could it be something else.
    new battery fitted last year
    Not getting any error codes
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    Exactly the same problem with mine,dont know what the problem is,i,ve never had any codes come up to solve it.
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    yes weird, sometimes its absolutely fine
    Mar 2012
    wakefield
    Trim : sri
    Mileage : 70000
    yes,my mate next door hates vauxhalls,its embarassing sometimes.
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    I guess nobody knows then, will have to take it to the garage
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Need to see live data when its happening.
    is it cranking ok just not firing?
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    I think its turning over ok but not firing, it has been ok today and yesterday, seems a bit random, but always starts first thing in the morning ok
    Mar 2012
    wakefield
    Trim : sri
    Mileage : 70000
    Has i said yours is very similar to mine,mine started up fine at 4 oclock this afternoon after work,then went to pick wife up at half 6 and was cranking for around 10 seconds before it started.
    I dont know about yours but my starter motor is slow at turning and abit noisy,tbh i think it could be a combination of the starter and glow plugs.
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    I thought starter motor would struggle from cold not from warm ?
    It started ok first thing yesterday even tho we had loads of snow.
    Carnoustie
    I.m having this problem too but with a 150, car is warm maybe left for 2 mins it spins over and kicks as if away to start then conks! only ever does it once and not every time, starter does seem to struggle and I would say is noisy, I changed the alternator and glow plugs oh and a new bosch high end battery thinking this was the problem!
    Maybe the compression is better when warm? hence harder to crank!!
    Ronnie
  1. 56 plate cdti 120 cold and poor starting
    By bigbadcat in forum Engine & Drivetrain
    Last Post: 5th June 2012, 17:28
  2. poor starting
    By tomo610 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 19:21
  3. Poor starting 1.9 CDTI 120 Hot & Cold
    By lehapau in forum Engine & Drivetrain
    Last Post: 4th October 2011, 20:06
  4. poor cold starting CDTi 120
    By bembo449 in forum Engine & Drivetrain
    Last Post: 21st May 2011, 16:53
  5. 03 vectra dti poor starting when cold
    By jono m in forum Engine & Drivetrain
    Last Post: 11th November 2010, 14:16
