Thread: Bulb out lights
    Regular Member stuk2000's Avatar
    Horncastle
    Default Bulb out lights
    Noticed on my Signum I keep getting rear right brake bulb out, but it works!! Everytime I reset it, it comes back!
    Also what bulb does the fog light take?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Means new bulb needed. Not working correctly as in, on way out.
    H1 for fogs.
    Horncastle
    So you think just put a new bulb in?? Also how do you access the settings on my display??
    Regular Member vanquis1979's Avatar
    gainsborough
    mazda gone stu?
    Dec 2011
    Seaham
    The bulbs may be on the way out, Or the bulb holders may need a clean.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    When u sorted the problem either replace bulb or clean it up a bit, will stop message popping up. No resetting or settings. Its just a "friendly" (but annoying if it keeps going off and on and off!!!) alert informing u of light needing attention.
    Horncastle
    Default Signum
    Quote Originally Posted by vanquis1979 View Post
    mazda gone stu?
    Yes mate, swapped it for the signum!! How you doing mate?
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Quote Originally Posted by stuk2000 View Post
    This is called the check system, it can be turned off via tech2 if u want it is anoying sometimes but handy, but as said there must be aomething wrong if its seeing a problem, bulb is easyest, do first.
    11 Post(s)
    Is the Signum like the Vectra, in that if the upper tail/brake light fails, then the lower tail light then becomes the tail/brake light instead?
    Regarding fog light - are you referring to the rear or front one?
    By default, you should only have one rear fog light - the offside one (uk spec), so if you're wondering why the nearside one isn't working, then it's not wired up.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Yes it does its a 21w bulb that the car runs 3v thru then the full 12v when brake light activates so its only one filiment thats how the car can do it, I belive its controlled via the REC.
    As for the fog light u could wire it to the nearside one as I have done, the bulb and fitting is there so its a nice easy mod.
  1. Bulb Replacement Light On When Lights Are OFF!
    By adam2628 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2012, 14:16
  2. Fog lights bulb - HB4?
    By zafira in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 04:03
  3. Bulb Replacement light on when lights off?? Help!!
    By Ryanrichards in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2009, 11:20
  4. Bulb waring light but lights work?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2009, 17:35
  5. Rear lights bulb cluster?
    By PeterVV in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2008, 01:15
