Results 1 to 10 of 11
Thread: Knocking in suspension / steering.
    Mar 2012
    Walsall
    Default Knocking in suspension / steering.
    this is really getting on my tits now, ive got a knocking noise thats developed since i changed the drop links.
    the drop links were ****ed before, with excessive play. so i sourced a new set and a different noise made itself apparent, a loud and solid sounding clunk when turning the wheel. just one knock, in no particular point through the steering wheel travel, and it doesnt make the noise when not moving..
    now its back to knocking at ever single bump on the road..
    i've checked the bottom ball joint and track rod ends, and i can see no play in them, and there is no play in the top mounts either..
    any ideas?
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Broken spring ?
    Mar 2012
    Walsall
    brand spanking new Eibach springs and Bilstein B8 shocks. springs are fine on inspection
    36 Post(s)
    Engine : 1.9 DTH
    Only ones left now is inner and outer tie rods and ball joint on lower arm
    Mar 2012
    Walsall
    i would have assumed that if it was the ball joints it would be apparent under acceleration or deceleration too.. nothing at all. ARB bushes maybe..?
    36 Post(s)
    Engine : 1.9 DTH
    Are u sure there is no play in top mounts ?
    Mar 2012
    Walsall
    none that i can see.. the 3 bolts securing them to the car are tight, and the strut top is secure too..
    36 Post(s)
    Engine : 1.9 DTH
    U not going to see it, remember I had a klonking noise when driving over a bump or deep in the road couldn't find anything , changed near side top mount , problem solved , what's age an mileage if u don't mind asking
    Mar 2012
    Walsall
    06, 43k.. inwent out with the spanners to tighten everything up and nothing budged at all.. I mean not even a fraction.. and the sound has gone away.. typical..
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Was going to suggest that it could be anti-rollbar related but sounds as though you've sorted it
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
  1. suspension knocking again
    By wirrallad in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2012, 18:30
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. Knocking suspension
    By cosjon in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2010, 14:55
  4. Knocking suspension
    By marko21 in forum Suspension, Wheels & Brakes
    Last Post: 22nd April 2008, 15:24
  5. Suspension Knocking
    By D-S-Dave in forum Suspension, Wheels & Brakes
    Last Post: 3rd August 2007, 01:31
