Thread: pictures of springs before they were fitted to your car
    Aug 2012
    Stockton-on-Tees
    Default pictures of springs before they were fitted to your car
    has anyone got any pictures of their springs before they fitted them to their car?
    More so the top of the front springs?
    The reason for this is due to the fact i bought a brand new set of Apex lowering springs -35mm and when i fitted them to the car the second coil from top seems to hit the outer casing on the bearing housing. Iv tested this by inserting a piece of rubber between the top two coils and the noise has completely stopped.
    For more Info See thread: clicking top mounts
    i just want to see if its the springs that are causing this issue or if its the struts them selves so i know if i need a refund or if i just need new struts. Personally i cant see the struts making a bit of difference as as soon as i go over a larger bump the second coil will be forced over the top coil again anyway.
    Thanks in advanced Craig
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    have you made sure they top collar is sat down on the the shock properly. i had this with another car and the collar wasnt seated properly. might be worth a check
    Aug 2012
    Stockton-on-Tees
    Quote Originally Posted by owen_999 View Post
    changed the the lot on the top.. new bearing, new top mount, suspensions been off 6 times now.. so i cant of fitted it wrong every time lol but no its not that.. its certainly touching the top bearing
    Aug 2012
    Hartshorne
    Trim : SRI
    i was on about the top collar that holds the spring in at the top. i sat one off slightly and it didnt go down on to the shock it just sat on the edge of it and made a racket
    Aug 2012
    Stockton-on-Tees
    theres photos of it on my other thread..
    theres a top bearing which is what the spring sits over and then a top mount im assuming when you mean top collar your talking of the bearing.
    Aug 2012
    Hartshorne
    Trim : SRI
    not the bearing its the plat that sits between the bearing and spring. i will try get a picture to show you. but your spring doesnt look aligned to the collar. it looks wonky to one side.
    Aug 2012
    Stockton-on-Tees
    well the springs certainly aligned in the bottom of the strut i cant get it to sit any further round!?
    if you can get a picture of this part thats meant to go between the bearing and the spring that would be very helpful
    at a guess does it look like a rubber boot that protects the strut and has a flat plate on it as well iv put that at that bottom but im beginning to think that might be meant to be at the top of the strut hanging down from the bearing rather then sittin on the bottom facing up.
    Aug 2012
    Hartshorne
    Trim : SRI
    It should be spring, metal plate ensure end of spring sides in to the recess then bearing secured by a nut before you it the rubber mount ready to be installed in to the car. You have to ensure the metal plate is far enough down for the bearing to locate on to the top of the unthreaded part of the shock. Will upload a picture when I get home from work
    Aug 2012
    Stockton-on-Tees
    got to be honest i need a diagram to show this.. After looking at a build up for the shock on some link someone sent for the vectra i have all the parts required apart from the disc that goes between the bearing and the top mount which apparently isnt needed any more and i certainly didnt have when i took the old springs off.
    the metal spring is slid into the recess at the bottom of the strut then at the top its just the bearing that sits on top of the spring and then the bearing sits onto the top mount.. im not sure what the part is that your talking about.
    thanks Craig
    Aug 2012
    Stockton-on-Tees
    have you managed to get a photo of this yet?
  1. k&n 57i fitted pictures please
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2011, 00:41
  2. opc badges fitted...pictures
    By blues n twos in forum Insignia car chat
    Last Post: 20th February 2011, 15:53
  3. HID's fitted with pictures
    By Knuckle in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2011, 01:46
  4. My springs are fitted
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 16:54
  5. pictures of hid's fitted
    By johnnyg in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 21:16
