Thread: no power and blue/white smoke
    Nov 2010
    Yorkshire
    Vehicle : Vectra Cdti 150
    Trim : Sri
    Engine : 1.9
    Mileage : 82000
    Default no power and blue/white smoke
    Hope you can help guys...ever since buying the car I have had nothing but problems with it. Its a 04 reg 150 cdti sri,full service history,1 owner and 77,000 miles. So far ive had a new dmf,alternator,inlet manifold,thermostat,turbo intercooler,turbo and new diesel filter all in 3 months ( glad I had a warranty ) Now the car is very low on power and at about 2500 revs loads of blue/white smoke comes out of the exhaust, I only got it back from the garage 4 days ago because of the same problem and they rectified it by replacing the diesel filter as they said it was collapsing in on itself therefore starving it from fuel. Any idea anyone before I take the car back in again
    Carnoustie
    DPF or EGR or bad injector?
    Ronnie
    Regular Member coldo's Avatar
    Scotland
    Blue / white smoke sugests oil is being burned.... Is the turbo very whiney at all? If the oil seals are failing the turbo will be down on power and oil will be getting through tot the engine being burned here.
    EGR is where I would start. Then the boost solinoid thing (cant remember what its name is). Swirl flaps checked. If this is all ok take the intercooler pipe off from the turbo feed end and see if their is oil in there. if this checks out check for cream on the oil car / coolant tank contamination as this may show head issues.
    Failing all that then I would be taking it to a garage to be checked out.
    C
    Nov 2010
    Yorkshire
    Trim : Sri
    Engine : 1.9
    Mileage : 82000
    Just took it to a m8 who is a mechanic and he told me straight away its an injector as its misfiring aswell, thansk for the replies guys and hopefully soon I will be enjoying my vectra
  1. loss of power and white smoke
    By stewsy in forum Engine & Drivetrain
    Last Post: 26th December 2012, 12:51
  2. Replies: 18
    Last Post: 20th November 2012, 21:41
  3. Low Power and white/blue smoke from exhuast
    By tait1983 in forum Engine & Drivetrain
    Last Post: 27th May 2011, 18:26
  4. White/Blue smoke on start up
    By jsr645 in forum Engine & Drivetrain
    Last Post: 15th May 2009, 22:26
  5. White/blue smoke at startup
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 27th March 2008, 08:57
vectra c 1.9 cdti no power
2005 vectra 1.9 cdti white smoke on start up and loss of power
vauxhall zafira blue smoke from exhaust
vectra diesel no power
vectra cdti blue white smoke
vectra 1.9 cdti lack of power white smoke using more diesel
vauxhall zafira 1.9 cdti inlet manifold smoking
vectra c cdti loss of power smoke and vibration
vectra cdti blue smoke site:www.vectra-c.com
1.9cdti no boost and blue smoke
vectra c 1.9 cdti wont rev and smokes bad
vectra 1.9 cdti sri white smoke and no power
1.9 cdti 150km white smoke no power
blue smoke and loss of power on vauxhall vectra
why is my vectra c bogging and smoking white smoke
white smoke when reving vectra sri
signum white and blue smoke and loss of power
vauxhall signum.blue and white smoke
vauxhall vectra C 1.9 CDTi smoking and no power
vectra c lacking power
vectra c 1.9 white smoke no power
