Results 1 to 10 of 25
Thread: Slow Starter Wouldnt Start 1.9 cdti 120
    Dec 2012
    Chatham
    Default Slow Starter Wouldnt Start 1.9 cdti 120
    Hi had my vectra a couple of weeks now and it has always been a slow starter, been having a read up to try and diagnose it correctly before i throw money at parts i dont need.
    This morning i left my house at 6 to go to the gym (4 miles) and it started up as it normally does after a few cranks. Left the gym at 8 and it started up fine, went home then left my house for work at 8:50 and it was just turning over and would not fire up, tried it for about 15 minutes then gave up and got a lift, then got a phone call from my dad 15 minutes after i got to work saying he tried it again when he got home and it fired straight up?
    Has anyone got any ideas what this could be? any help would be greatly appreciated as at the moment i am dreading driving it anywhere in case i get stuck!
    Thanks in advance
    Regular Member owen_999's Avatar
    Aug 2012
    Hartshorne
    Vehicle : Vectra SRI 150
    Trim : SRI
    Engine : 1.9cdti 150
    might be worth getting your battery tested. it might have enough voltage but not enough amperage to work.
    might also be worth getting an inspection or test of your starter
    Dec 2012
    Chatham
    the battery looks fairly new and it has ha a brand new alternator due to the pulley being knackered. is there a way to test the starter without removing it?
    wirral
    27 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    You got a multimeter?
    Dec 2011
    Seaham
    Also check your glow plugs. Try recycling them a few times then try to start the car.
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    More than likley your starter motor its a common prob on 120s
    gaz
    Jan 2013
    Chester
    Vehicle : Vectra estate xp cdti
    Trim : Sri xp
    Engine : 120 cdti
    Ours was the same,changed the battery 1st,then glow plugs,then finally the starter.
    I would bet money its your starter that needs replacing
    Dec 2012
    Chatham
    I do have a multimeter, I did suspect starter motor before but I just thought it was strange how it wouldn't fire up just that once, felt like a fueling problem. Also should the glow plug light come on every time the engine is started or just when it's cold?
    thanks
    hull
    Mine was like that when i looked at it to buy, took ages to start, dealer changed starter, problem solved.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by mattclayt View Post
    Thanks in advance
    Check yourself
    The spill pipes on the tops of the injectors the rubber perishes and allows air into the system.
    Diesel filter for signs of blockage/dirty
    Diesel filter housing for signs of leaks
    If ok
    Take to auto-electricians and check.
    Battery
    Starter motor
    Glow plugs
    Temp sensor
  1. wouldnt start
    By vecsxi in forum Engine & Drivetrain
    Last Post: 5th June 2012, 17:17
  2. slow start
    By ANDY GSI in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 00:10
  3. car wouldnt start?....starter?
    By Jaspa in forum Engine & Drivetrain
    Last Post: 27th March 2011, 17:30
  4. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
  5. Car went in big puddled and stalled and wouldnt start for ages
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 18th July 2009, 00:14
vectra cdti slow starting
vectra c slow starting
vauxhall vectra diesel lazy starter
vectra c 1.9 cdti starting problems temp sensor
vectra starter turning slow
vectra c starter check
vectra z19dt oil filter cooler leaked www.vectra-c.com
vectra c 1.9cdti starter
vectra c z19dt starter turning too slow
www.vectra-c.com vauxhall vectra starter motor removal site:www.vectra-c.com
vectra 1.9 cdti starting problems
1.9 cdti lazy batterry
vauxhall vectra lazy starter
vectra c weak start
