Thread: What have i done?
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default What have i done?
    Fitted new front pads on the GSi this evening.
    Went for a run up the road, now the NS Xenon is pointing to the floor about 6ft in front of the car. Have i disturbed something?
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Knocked headlight ? Flat Tyre ? Broken Spring ?
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i would think youve upset the auto leveller somehow,if my memory serves me right I think the gsi has auto levelling headlights .
    do a search .
    Mar 2012
    Norway
    Original xenons is always auto leveling due to regulations/laws.
    On my Vectra, it's a small sensor fitted from the chassis and a sensor-stick out on the suspension arms. These are mounted on either the driver or passenger side - not both, and their assignment is to check the load on the front and back of the car and then adjust the headlights up and down to prevent dazzle/glare to other traffic.
    My best bet is one of these sensors or the cables to them.
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Isn't there a small leveller on the wishbone my omega used to have them but if the arm was off it used to throw a error up on the info screen
    Berinsfield,Oxford
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Yes the sensor is on the NSF wishbone. Might try disconnecting it and see if it resets.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Used to be a common one on Omegas as has been mentioned. If the front had been jacked up for whatever reason, the level sensor either went out of range or the little arm popped off. Typically, this threw up an 'Out of Range' or similar warning or you just got one or both lamps in the 'failsafe' position looking a few feet in front of the car.
    If the arm was off, just popping it back on fixed it, if it had gone out of range then it normally reset once switched off and back on, but occasionally required the fault clearing or a 'battery off reset'.
