Results 1 to 10 of 23
Thread: SRi Ride is reall hard
    Nov 2012
    Stoke-on-Trent
    Default SRi Ride is reall hard
    Sorry if i sound abit dumb here but does the SRi vectras have a different/stiffer suspension set up to say an LS? Etc... My mum has a 2003 LS vectra 1.8 and its a real smooth ride when iv driven it, my 2006 SRi is SOLID compared to it and jumps and feels every bump, also iv noticed the front and rear to sort of bang when going over potholes etc like theres no give in the suspension at all, it could be normal but as iv never driven another SRi i wouldnt know. i do know the anti roll bar bushes on the front need changing would that cause the steering to feel unsteady over bumps etc or not?
    thanks all
    Regular Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    Its a sports spec hence the stiffer suspension for better handeling and cornering and a sportyer look
    Regular Member jazzisri's Avatar
    Dec 2012
    Rotherham, South Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 200
    the sri's have a 20mm drop over standard setup iirc
    Northampton
    Engine : A20DTH
    Mileage : 88000
    SRi,s have a 15mm drop from standard not 20mm.
    chances are your springs have broken and depending on your mileage the shocks might need replacing. If its still on genuine shocks and mileage is 70k plus then they will be worn. you should not be getting bangs when you go over potholes. I have Bilstein B6's and Eibach lowering springs on mine and they are much harder than the Sri setup and they do not bang over potholes
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    SRi and early SXi spec had 15mm lower springs and different stiffer shock absorbers. The rims are also bigger. All that combined will be why the LS feels softer! Having said that though, it's not normally that bad. With you saying it knocks and bangs, get the suspension checked out. The springs are made of chocolate and if they've snapped or the shocks are worn, that would explain it.
    Nov 2012
    Stoke-on-Trent
    The cars done 71,000 miles it just seems abit unstable amd erratic over bumps sometimes, i know the springs are crap as my dads has his done twice, the car was only motd in november so i imagine ifnthere was a problem it would of been picked up there?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by cont1204 View Post
    You've got that the wrong way round, early SXi's had standard suspension, the later ones were fitted with SRi suspension.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Veccy55 View Post
    The MOT rarely picks up dead shocks unless they show signs of leaking and they can miss broken springs (my last four cars I have had can prove this comment). At 71k the shocks are well due for a change. Springs can break when the car is sitting on the drive so even if they were ok at the MOT is does not mean they are ok now
    Regular Member HenryD's Avatar
    Nov 2012
    cornwall
    My Signum Elite feels stiff after my Omega which was like a big armchair,do the 3.0 Signum Elites get sports suspension as standard kit?
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    When I was looking for a vectra I test rode a few and amongst them some SRIs and it is true that they feel super hard compared to an LS with its much softer suspension smaller wheels and higher profile, and driving sri you feel not a bang but a solid thud when you hit a pot hole or even sometimes shallow road imperfections, that's why I went for a design and all the confort instead.
  1. Hard ride over potholes
    By Mike RB in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2011, 10:04
  2. Ride is so hard 2.2 sri
    By banjokazooie in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2011, 19:13
  3. can someone put these on my ride please?
    By chrosty in forum Photoshop section
    Last Post: 15th December 2010, 13:22
  4. Hard ride with a VXR kit?
    By shark and mel in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 09:34
  5. Replies: 7
    Last Post: 6th July 2007, 11:10
insignia sri hard suspension
signum suspension too hard harsh
how to get softer ride in insignia sri
insignia sri hard ride
insignia sri too bumpy
vectra c xp hard ride
vectra hard suspension
