Thread: Rear Knoking
    Jul 2012
    Derby
    Default Rear Knoking
    I have a 54 19 cdti estate and recently I have been having a knocking noise from the rear nearside. The noise isnít all the time and seems to stop whilst braking and for a sort time after. I havenít had time to investigate it properly yet but was wondering if anyone else had the same issue and could tell me what to look for.
    My first thoughts are wheel bearing?
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    9 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    A wheel bearing would make a rhythmic 'grumbling' noise, I should have thought. It sounds like your rear anti-roll bar mounting bushes might need replacement. I may be wrong. They are only something like £6 for the pair, as far as I know. I need to replace mine, as well as my front ones. Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    ARB's or upper control arm bushes.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    If it stops when braking, it'll be your rear pads. Mine done it. Sorted by removing the pads, cleaning the calliper around where the pads sit, and re-seating the pads. Might be worth changing them if they are low
    Jul 2012
    Derby
    Right just checked the rear I think it is coming from and there is no play when you shake the wheel but when striped the brakes down I've found that the locating lugs on the piston face don't match the ones on the pad! Has Someone at some point put the wrong pads in? They're where done just before I bought it 4-5 months ago.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    They'll be aftermarket pads. Same with mine. Slightly different fit. Best use OEM ones
    Jul 2012
    Derby
    Just look and they have put the pads with the lugs on one side and the one with the springs on the other. Have you changed yours?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by scottc View Post
    I've put my cheapie euro car parts ones back in for now. Used lots of copperslip on re-assembly and cleaned callipers thoroughly on re-assembly. Rattle has just about gone. Can barely hear it only if you go over rough ground.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    Quote Originally Posted by tony-1977 View Post
    Jul 2012
    Derby
    so after stripping the nearside last night and finding the pad are put in wrong I had to build it back up the same way as I needed the car last night but there has been no knocking either last night or today. Tomorrow I will strip both sides down and do it correctly!
    Thanks for the advice its much appreciated!
  1. Condensation on Inside Rear Driver Side Rear Panel
    By akeem in forum Bodywork & Interior
    Last Post: 26th November 2012, 22:12
