Results 1 to 10 of 11
Thread: M32 gearbox to an f40?
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Default M32 gearbox to an f40?
    I know some of the 8v 1.9 engines had these so it can't be impossible, but how much work would there been in swapping my m 32 for an f40? New driveshafts and box? Or would there be more needed?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    More mate the f40s a completely diffeent shape
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    So all linkages etc?
    hull
    Why would you want to swap it? Just had my m32 rebuilt with new bearings(common fault) and is so smooth and quiet now.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by frasedeb View Post
    I guess mate that's the reason why so he doesn't have to rebuild it f40 are very good boxes very rarely u hear about one that's gone
    hull
    Quote Originally Posted by Sebastian View Post
    True F40 box is good, but to do the conversion would cost more than a bearing upgrade on m32 i think, F40 is bigger box with different linkages/driveshafts etc i think.
    F40 can handle more power though if he's remapped engine.
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Only reason is I've got a crack in my sump plug drain casing which is leaking slightly (5 or so drops on to the floor over a couple of days) I've found out I can just replace that part but unsure how hard it'd be"/
    36 Post(s)
    Engine : 1.9 DTH
    Subframe drop job mate
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Oh nice"/ you done one before then sebastian?
    hull
    Ring this guy mate, he rebuilt my m32 box over xmas, does loads of vecs/astras. He'll tell ya what needs to be removed to replace the end casing, he's got a load of cracked ones too(common problem with m32). He's called TOM.
    07702562283 (atom transmissions)
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
convert m32 gearbox to f40
m32 gearbox f40 conversion
m32 gearbox swap
m32 to f40 conversion
